Teardown
This is a teardown of the Samsung SCH-8500.
This teardown is not a repair guide. To repair your Samsung SCH-8500, use our service manual.
The phone we are taking apart today is the Samsung SCH-8500
Press on black button next to battery and use metal spuger or other pointy object to pop the battery of the back.
Remove 4 0.6mm screws with a T6 Screwdriver.
Remove the little rubber piece.
Then gently lift off back case.
Unscrew the antenna from back case.
Pry off the 2 covers on the display.
Remove the 2 0.3mm screws from display
Pry the speaker cover off display, to reveal 2 screws.
Remove 2 0.3mm screws.
Use a case opening tool and pry the case of the display.
Pry the display, speakers, and main board of of phone
Take off the keys
Voila! You're done.
131 Reputation
1 Guide authored
Badges: 3
Choose a size and copy the code below to embed this guide as a small widget on your site / forum.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 16
All Time: 894
