Rubik's Cube Teardown
Teardown
Teardown
Teardowns provide a look inside a device and should not be used as disassembly instructions.
User-Contributed Guide
This guide is not managed by iFixit staff.
  • Add Note x
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 1 — Rubik's Cube Teardown  ¶
  • Turn the top row so that each corner is roughly halfway between the sides
  • Push the pieces up until they pop out of the cube, then, slide the rest out
  • Repeat this process until you clear the level
first image
thumb image 1
thumb image 2
Add Note Edit Step 2  ¶
  • You should be able to just directly pull out the rest of the blocks, like so
  • And there you have it!
  • You'll have the center piece, with the six centers of the six sides, the turning mechanism
first image
thumb image 1
thumb image 2
Add Note Edit Step 3  ¶
  • To reassemble, snap all the pieces back into place, and try not to rotate the faces.
  • It helps to start with the middle pieces first
  • Don't be afraid to use force!
  • Once you have the middle pieces in it's pretty simple to just push in the corner pieces
  • Again- don't be afraid to use force!
