This teardown is not a repair guide. To repair your Razer Blade 14" (2013), use our service manual.
  1. Razer Blade 14 (2013) Teardown, Razer Blade 14 (2013) Teardown: step 1, image 1 of 2 Razer Blade 14 (2013) Teardown, Razer Blade 14 (2013) Teardown: step 1, image 2 of 2
    • The thin and sleek gaming Notebook from Razer.
  2. Razer Blade 14 (2013) Teardown: step 2, image 1 of 3 Razer Blade 14 (2013) Teardown: step 2, image 2 of 3 Razer Blade 14 (2013) Teardown: step 2, image 3 of 3
    • Remove the 10 Screws holding the back Cover on to reveal the mainboard.
    • DDR3 Ram chips
    • CPU Chipset
    • Liteon 256gb SSD (factory installed)
    • Factory WLAN/BT card
    • Battery
    • Aftermarket MSata SSD (installation screw not included)
  3. Razer Blade 14 (2013) Teardown: step 3, image 1 of 3 Razer Blade 14 (2013) Teardown: step 3, image 2 of 3 Razer Blade 14 (2013) Teardown: step 3, image 3 of 3
    • Removing the Battery
  4. Razer Blade 14 (2013) Teardown: step 4, image 1 of 3 Razer Blade 14 (2013) Teardown: step 4, image 2 of 3 Razer Blade 14 (2013) Teardown: step 4, image 3 of 3
    • Apparently this notebook was named even before i got it! In my use this battery will last through 4-5 hours of movies on power saver mode.
  5. Razer Blade 14 (2013) Teardown: step 5, image 1 of 2 Razer Blade 14 (2013) Teardown: step 5, image 2 of 2
    • Removing the Speakers.
  6. Razer Blade 14 (2013) Teardown: step 6, image 1 of 3 Razer Blade 14 (2013) Teardown: step 6, image 2 of 3 Razer Blade 14 (2013) Teardown: step 6, image 3 of 3
    • The original mSATA SSD. (the secondary seen earlier was added by myself.
  7. Razer Blade 14 (2013) Teardown: step 7, image 1 of 3 Razer Blade 14 (2013) Teardown: step 7, image 2 of 3 Razer Blade 14 (2013) Teardown: step 7, image 3 of 3
    • Removing the fans.
  8. Razer Blade 14 (2013) Teardown: step 8, image 1 of 3 Razer Blade 14 (2013) Teardown: step 8, image 2 of 3 Razer Blade 14 (2013) Teardown: step 8, image 3 of 3
    • Removing the heatsinks.
  9. Razer Blade 14 (2013) Teardown: step 9, image 1 of 3 Razer Blade 14 (2013) Teardown: step 9, image 2 of 3 Razer Blade 14 (2013) Teardown: step 9, image 3 of 3
    • Removing the mainboard.
  10. Razer Blade 14 (2013) Teardown: step 10, image 1 of 3 Razer Blade 14 (2013) Teardown: step 10, image 2 of 3 Razer Blade 14 (2013) Teardown: step 10, image 3 of 3
    • This is the end of the teardown. anything past this point would likely cause damage to the notebook and as i intend to continue using it, this would be undesirable. Just one thing i noticed, that there is an debug ribbon cable plug left on the board, another thing, the power plug is replaceable.
tallme15
902 Reputation
2 Guides authored
43 Comments
Great work, very, very professional ! And thanks, was really curious to see how one looks on the inside !
Darie H - Reply
Awsome Teardown! Thanks A bunch!
my91331 - Reply
Thanks a bunch everyone! With all the recognition I've gotten with this teardown I decided I would redo it with pictures taken on a proper DSLR and more of them and more indepth captions for the individual steps, I may even make some replacement guides!
tallme15 - Reply
Is that a second mSATA slot I see on the left side of the motherboard underneath the large ribbon cable?
Bryce - Reply
Indeed it is! it functions too, the stock is beneath the cable, the unpopulated is the exposed one, that i had installed an Mushkin atlas in and started using without a hitch.
tallme15 -
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 21
All Time: 57,525
