Power Mac G4 Quicksilver Teardown
Teardown
Teardown
Teardowns provide a look inside a device and should not be used as disassembly instructions.
Featured Guide
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
User-Contributed Guide
This guide is not managed by iFixit staff.
  • Add Note x
The Powermac G4 "Quicksilver," The 2nd Major revision to Apple's Powermac G4 Series. It was released in 2001, and came with a 533Mhz-Dual 1Ghz Motorola PowerPC G4 CPU. This Supported up to 1.5GB of PC133 133Mhz Ram. This computer looks neat, and was the last apple computer to incoorperate a possible ZIP Drive. It had AGP Graphics with a NVIDIA GeForce 2MX Mac Edition standard. This is incredibly silent compared to the G4 MDD and the G4 Graphite. Available CPU Speeds: 533Mhz, 667Mhz, 733Mhz, 800Mhz, 933Mhz, And 1.0Ghz . Most clock speeds were available in both single and dual configurations. This was the first Mac to reach 1.0Ghz. No wonder they call it the "Quicksilver."
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 1 — Power Mac G4 Quicksilver Teardown  ¶
  • The Powermac G4 "QuickSilver"
  • Unfortunately, my zip drive bezel fell off.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 2  ¶
  • Start by opening the case.
  • The same way, the other powermac g3's and G4's open... Just lift the lever on the side of the case, and lower it down.
  • This gives us access to the guts.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 3  ¶
  • Ram
  • Hidden between the cpu and the graphics card is the ram.
  • the quicksilver uses PC133 133Mhz Ram and supports up to 1.5Gb, just like the cube.
  • The Original ram is Labeled "KingMax." Some Type of Kingston Knockoff?
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 4  ¶
  • The AGP Graphics Card:
  • Remove this screw, then push in this tab outward, and pull the card out.
  • The Quicksilver came standard with this card, a 32MB NVIDIA GeForce 2MX AGP Mac Edition, this card supports the ADC Displays like the one we took apart last week.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 5  ¶
  • AirPort Card:
  • Remove the AirPort Antenna by pulling it out of the back of the card
  • Grab the plastic tab, and pull the card out.
  • This is the same PCMCIA 802.11b Airport card found in every mac from 2000-2004, it is only wireless "B" so you only get 11Mbps, but that is enough for web browsing.
  • This Space Intentionatly Left Blank
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 6  ¶
  • Removing The CPU Fan:
  • Remove these 2 Phillips screws.
  • Then Remove the fan connector.
  • Then, remove the fan.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 7  ¶
  • CPU:
  • This Computer boasts a 733Mhz Motorola PowerPC G4 CPU, though not fast enough to run leopard natively, it runs 10.4.11 "Tiger" fine.
  • It has a 733Mhz Motorola PowerPC 7450 (G4).
  • Start by removing the heatsink clamps with a flathead screwdriver.
  • Do the same for the other side.
  • Then Lift off the heatsink.
  • This will reveal the CPU.
  • Remove these screws.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 8  ¶
  • Once those screws are removed, carefully remove the CPU.
  • This is apple's 300-Pin connector, it is found on this Mac, and MDD's (This cpu won't work in an MDD) and similar to the one in PowerMac G5's.
  • This connector is incredibly hard to remove, because of the way it connects, it is also very hard to remove without damaging it, if you don't pull it straight up, you will, most likely damage it.
Next » « Previous
Required Tools
Phillips #0 Screwdriver
$4.95 · 50+ in stock
6-in-1 Screwdriver
$4.95 · 3 in stock
Recommended Tools
Home Tech Toolkit
$24.95 · 50+ in stock
Sorting Tray
$7.95 · 50+ in stock
Anti-Static Wrist Strap
Pro Tech Base Toolkit
$59.95 · 50+ in stock
Thirsty Bag
$6.95 · 50+ in stock
Popular Products
iPhone 4S Rear Glass Panel
$79.95 · 16 in stock
Plastic Opening Tools
$2.95 · 50+ in stock
Precision Tweezers Set
$7.95 · 28 in stock
Pro Tech Toolkit Expansion 2
$59.95 · 31 in stock
iPod Touch Gen 4 Display Assembly
$69.95 · 50+ in stock
Notes Add Note Notes are offturn on
