first image
thumb image 1
thumb image 2
Add Note Step 17
  • The Blu-ray drive comes right out.
  • This drive is still quite large, and takes up the bulk of the space inside the PS3.
  • We disassembled the drive, and found that it appears to be a proprietary Sony-manufactured part.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Step 18
  • More connectors and screws to unplug/unscrew.
  • The design aesthetic of this machine is quite a bit more bare-bones-functional than Apple's, but is still beautiful in its own way.
  • Several components, including the AC power inlet, are simply held to the unit by the pressure of the screws connecting the top and bottom cases.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Step 19
  • A few more screws, and the logic board lifts free of the chassis!
first image
thumb image 1
thumb image 2
Add Note Step 20
  • Unscrewing several screws securing the EMI shield.
  • The two identical matte finished brackets in the first picture are designed to apply pressure to the center of the processors, keeping them firmly planted on their heat sinks.
first image
thumb image 1
thumb image 2
Add Note Step 21
  • Separating the metal electromagnetic interference shield from the logic board.
first image
Add Note Step 22
  • The whole [slim] enchilada!
  • Counterclockwise from the left:
    • Power supply, main board, hard drive, EMI shield, heat sink, fan, Blu-ray drive, controller, and plastic case.
first image
thumb image 1
thumb image 2
Add Note Step 23
  • That's it for the disassembly, but we'll continue to post board photos and analysis as the information pours in.
  • The logic board. Sony's going green on the inside, to reflect their commitment to the environment. View HUGE version.
  • We've never seen cool snowflake-like patterns in the thermal paste after we removed a heat sink before. This may indicate that the thermal paste was overapplied or that it was not distributed evenly.
  • If you look closely at the thermal paste, you'll see it is a fractal!
first image
thumb image 1
thumb image 2
Add Note Step 24
  • The Cell processor looks very spiffy under our lights.
  • We didn't think it was possible to synthesize reality, but the RSX chip (from an Acura?!) proves us wrong.
  • Chip labels: RSX Reality Synthesizer CXD2991EGB 0916HFZ 114477
Add NoteNotes: Step 17
Flag Reply by afrangel Aug 27 2009 @ 2:59 AM
Is the lens on the Blu-ray drive exact as on previous versions?
I have already replaced it twice on my 80GB PS3
Flag Reply by Jake1y Oct 22 2009 @ 6:54 AM
Whats the cr2032 battery for? Does ever need to be replaced?
Flag Reply by maui boy no ka oi Nov 9 2009 @ 3:53 PM
Quote from Jake1y:
It's to keep the system's internal clock running. It should be replaced when it runs out, but that will probably take years to do (and even if you don't, the lack of a clock isn't so bad).
Flag Reply by Iredel Mar 4 @ 8:38 AM
Hello i bought the PS3 Slim 120GB and it says on the PS3 back that it supports 120V~2.1A - 60Hz i live in Israel and the power supply here is 220v i i have a converter that have a Fuse Protection Input: 220 or 110 AC 50W Output: 110 or 220 AC 50/60Hz can i use it in Israel with that? and i saw that u said that i only need to change the power cord and it will work in 220v, are you sure that its right?? couse people told me that if i'll do that with 220v cord the muchine can blow up
Add NoteNotes: Step 23
Flag Reply by surfsmurf Aug 26 2009 @ 5:38 PM
I wouldn't want to have to change that CR2032 battery! At least it's not soldered to the board...
Flag Reply by ryan1909 Aug 27 2009 @ 5:24 AM
Why do they not use silver paste
Flag Reply by miniskunk Aug 28 2009 @ 5:14 AM
I am thinking it's a good thing you took it apart as this creates the perfect opportunity to do a better thermal paste application.
Flag Reply by Xenicus Sep 5 2009 @ 2:00 AM
Oh, it would appear from the motherboard that we won't be seeing a slim with more than 2 USB ports in the future (I was hoping the rumoured 250Gb version would have more than 2). Very frustrating - my 60Gb has 4.... so I am not sure if I should 'upgrade'....
Add NoteNotes: Step 24
Flag Reply by katboi Aug 26 2009 @ 12:22 PM
That is Beautiful. Do you have a picture from a better angle? Like the one of the RSX.
iFixit Staff
Flag Reply by Andrew Bookholt Aug 27 2009 @ 2:31 AM
Quote from katboi:
Unfortunately, the laser etching on the face of the cell processor is nearly invisible when viewed straight-on like in the RSX picture. We had a hard enough time making the text visible on the shot we have (notice the reflection on the board).
Flag Reply by razin Aug 28 2009 @ 6:47 AM
I want know,Cell still use 7 SPE or by advantage of 45nm use 8 SPE.
Flag Reply by MeltedRabbit Sep 1 2009 @ 5:12 AM
Quote from razin:
I'm going to guess it still uses seven, it may only have seven SPE on die this time though. Adding a couple additional features on a new version of an older console has a habit of making owners of the older version angry. It would result in developers having to add additional time for development on games for each console version, another non-starter.
BTW, where are the GDDR3 chips that should be present near the RSX?
Flag Reply by HalTheHacker Sep 9 2009 @ 10:45 AM
Interesting how the chip is labelled 'Reality Synthesizer'
IIRC the equivalent chip on the PS2 was labelled 'Emotion Engine' I always figured that was what made my PS2 so temporomental :P (ok so I never had a PS2, but you get my point)
