Image #1 Image #2
Add Note Edit Step 9  ¶
  • The wireless card is easily identifiable by the mess of antenna cables connected to it.
  • A flick of our magic spudger frees the wireless card for inspection.
Image #1
Add Note Edit Step 10  ¶
  • With surgical-like precision and care, we remove the EMI shields from the wireless card to reveal:
    • Qualcomm PM8028 power management
    • Avago ACPM-7868 linear quad-band power amplifier module
    • Epcos 7964 SAW duplexer
    • Avago ACPM-5001 CDMA band 1 power amplifier module
    • Avago ACPM-5002 CDMA band 2 power amplifier module
    • Avago ACPM-5005 CDMA band 5 power amplifier module
    • Avago ACPM-5008 CDMA band 8 power amplifier module
Image #1
Add Note Edit Step 11  ¶
  • Turning our attention to the backside of the wireless card we find:
Image #1 Image #2
Add Note Edit Step 12  ¶
  • The PS Vita is very modular. Check out all these connectors!
    • Having all the components on a single ribbon cable or PCB makes repair both difficult and costly. With all these individual components, the Vita should be easy to repair.
  • We detach a few connectors and remove the SIM card board from the colorful innards of the device.
Image #1 Image #2
Add Note Edit Step 13  ¶
  • Recruiting the help of our spudger, we remove the rear-facing camera.
  • Though the Vita is the first Sony handheld device to boast a camera, you shouldn't cancel your D800 pre-order quite yet. The 640x480 pixel VGA quality (0.3 MP) camera isn't likely to wow the folks browsing your Flickr stream.
Image #1 Image #2 Image #3
Add Note Edit Step 14  ¶
  • After a fair amount of disassembly, we find our old nemesis: adhesive!
  • We easily win the battle against the evil glue with our trusty plastic opening tool and separate the rear multi-touch pad from its frame.
  • Attached to the rear touchpad, we find an Atmel mXT224 touchscreen controller.
Image #1 Image #2
Add Note Edit Step 15  ¶
  • Once the back case is off, components start flying out of the PS Vita faster than you can say "thirsty bag."
  • The speakers come out without much fuss thanks in part to their pressure contacts. These types of connections are common in devices where space is a concern and there's no room for routing and soldering speaker wires.
  • With many modes of connectivity comes a whole bundle of antennas. Head-to-head gaming sure has come a long way.
Image #1 Image #2
Add Note Edit Step 16  ¶
  • The trigger buttons are easily removed and are a simple, modular design. This means easier and cheaper repair for the masses!
  • If it ain't broke, don't fix it. Sony has used the same basic design for the R and L trigger buttons since the original PSP.
Next » « Previous
Required Tools
Spudger
$2.95 · 50+ In stock
Phillips #00 Screwdriver
$4.95 · 50+ In stock
Plastic Opening Tools
iFixit Opening Picks set of 6
$6.95 · 37 In stock
Recommended Tools
Universal Drive Adaptor
$29.95 · 50+ In stock
iFixit Lock Pick Set
$29.95 · 11 In stock
Inspection Scope
$39.95 · 37 In stock
Frictionless Ratchet
$24.95 · 47 In stock
Portable Anti-Static Mat
$24.95 · 15 In stock
Popular Products
Soldering Station
$24.95 · 12 In stock
Small Suction Cup
Magnetizer/Demagnetizer
