This teardown is not a repair guide. To repair your PlayStation Move, use our service manual.
  1. PlayStation Move Controller Teardown, PlayStation Move Controller Teardown: step 1, image 1 of 1
    • Playstation Move Controller
  2. PlayStation Move Controller Teardown: step 2, image 1 of 1
    • Remove the 4 screws holding the back over and trigger button on.
  3. PlayStation Move Controller Teardown: step 3, image 1 of 2 PlayStation Move Controller Teardown: step 3, image 2 of 2
    • Once open you will see two ribbon cables.
    • The one connected to the trigger button is removable.
    • The ribbon cable attached to light globe is soldered on.
  4. PlayStation Move Controller Teardown: step 4, image 1 of 3 PlayStation Move Controller Teardown: step 4, image 2 of 3 PlayStation Move Controller Teardown: step 4, image 3 of 3
    • Light Globe Cover and the LED Module can be separated.
  5. PlayStation Move Controller Teardown: step 5, image 1 of 1
    • The battery can easily be removed. There is connector on the side of the board.
    • Battery Specs: Single Cell 1380 mAh 3.7 Volt
    • Sony Part: LIS1441
  6. PlayStation Move Controller Teardown: step 6, image 1 of 1
    • Remove the inner plastic (1 Screw) frame to expose the logic board
    • Remove the 2 top screws and one bottom screw to remove the logic board from the controller.
  7. PlayStation Move Controller Teardown: step 7, image 1 of 3 PlayStation Move Controller Teardown: step 7, image 2 of 3 PlayStation Move Controller Teardown: step 7, image 3 of 3
    • Logic Board
    • Chip Closeups Included
    • 503A 04c ALPS - Radio Module
    • AKM8974948D - MEMS Gyroscope
mcwiggin
616 Reputation
3 Guides authored
One Comment
AKM 8974 - 3-axis Electronic Compass
Xeno - Reply
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 56
All Time: 18,447
