PlayStation 3 Teardown
Teardown
Teardown
Teardowns provide a look inside a device and should not be used as disassembly instructions.
User-Contributed Guide
This is a teardown of an original launch 60GB PlayStation 3 system. One of the best units out there that had backwards compatibility and the card readers. Sadly this unit has a GPU a problem so it's broken.
Edit: Nickname fix, formerly Karasumachitose. Apologies to any inconvenience this causes.
Image #1 Image #2 Image #3
Add Note Edit Step 1 — PlayStation 3 Teardown  ¶
  • There she is, one of the two original PS3 models available at launch (60GB).
  • It's got PS2/PS1 backwards compatibility and a multi-card reader. The current PS3 Slim doesn't have the card reader. The other launch model lacked the card reader and WiFi (20GB).
Image #1 Image #2
Add Note Edit Step 2  ¶
  • Let's get started!
  • Remove the hard drive access cover from the bottom of the PS3.
Image #1
Add Note Edit Step 3  ¶
  • Use the Phillips screwdriver #1 to remove the blue screw.
Add Note Edit Step 4  ¶
  • Lift up the metal lever.
  • Slide the hard drive towards the front of the case.
  • Pull it straight up and out of the unit.
    • This is all you need to do to access the PS3's hard drive.
Add Note Edit Step 5  ¶
  • Remove the warranty sticker.
    • Obviously this voids your warranty. You have been warned.
  • Use your fingers and pry up and remove the foot underneath the sticker.
Image #1 Image #2
Add Note Edit Step 6  ¶
  • Use the Torx Screwdriver (T8 or T10) to remove the torx screw from the space behind the rubber foot.
    • This screw has a security bit but most are able to remove it successfully with a normal Torx driver.
Add Note Edit Step 7  ¶
  • Place PlayStation face up such that "PlayStation 3" is oriented so you can read it.
  • Place your palm on the PlayStation 3 logo and slide the plastic front cover towards you and off of the outer plastic shell. Set it aside.
Add Note Edit Step 8  ¶
  • Remove the metal receiver that held the torx screw you just removed.
Next » « Previous
Required Tools
Spudger
$2.95 · 50+ In stock
Phillips #00 Screwdriver
$4.95 · 50+ In stock
Phillips #1 Screwdriver
$4.95 · 5 In stock
Phillips #2 Screwdriver
$4.95 · 5 In stock
T8 Torx Security Bit Screwdriver
$6.95 · 50+ In stock
Recommended Tools
Universal Drive Adaptor
$29.95 · 50+ In stock
iFixit Lock Pick Set
$29.95 · 25 In stock
Inspection Scope
$39.95 · 39 In stock
Frictionless Ratchet
$24.95 · 48 In stock
Portable Anti-Static Mat
$24.95 · 18 In stock
Popular Device Products
