PlayStation 3 Slim Teardown
Teardown
Teardown
Teardowns provide a look inside a device and should not be used as disassembly instructions.
A first look inside Sony's dramatically redesigned, cooler, sleeker PlayStation 3 Slim! Also check out our PS3 Slim teardown video on YouTube!
Image #1 Image #2
Add Note Edit Step 1 — PlayStation 3 Slim Teardown  ¶
  • It's here! We got our dirty hands on a PS3 Slim a full day before it was set to arrive in the mail!
  • The box, just like the unit, is, well, slimmer.
  • Did you know you can post your own teardown on iFixit? Share what's inside your gadgets! Take apart an old cell phone, microwave, or toy robot.
    • Our free online editor makes it super-easy to publish step-by-step teardowns.
    • We host everything for free, and make it easy for you to have high-resolution photos, professional layout, and full-screen slideshows like ours!
Image #1 Image #2 Image #3
Add Note Edit Step 2  ¶
  • Along with the PS3 Slim you get:
    • Sixaxis DualShock 3 controller
    • RCA Cables
    • USB Cable
    • Power Cord
    • QuickStart Guide and Instruction Manual
    • Welcome to PS3 and PS Network Blu-ray Disc
    • One of those "Guide to Video Game Ratings" guides that nobody gives a [redacted] about.
Add Note Edit Step 3  ¶
  • On the front left we have two USB ports, a hard drive indicator light, and a Wi-Fi indicator light.
  • Front right yields a slot-loading Blu-ray drive, power button, and eject button.
  • The back has a LAN connection, HDMI port, digital audio-out, multi-connector (RCA or component video) and a new type of power plug.
  • Owners of the current-gen PS3s will notice an absence of the rear manual power switch. All your powering needs are now served by the front power button.
Image #1 Image #2
Add Note Edit Step 4  ¶
  • Now that we've dispensed with the pleasantries, let's get into the meat of the subject, so to speak.
  • We start with the hard drive first.
    • A blue Phillips screw is hidden beneath "the blue Phillips screw cover," as we call it. Remove this screw.
      • You can view this blue Phillips screw in all its glory if you'd like.
    • Next, remove the hard drive cover.
Image #1 Image #2
Add Note Edit Step 5  ¶
  • The drive enclosure has a metal pull tab attached to it. Pull on it to release the drive from the bay.
  • The 120 GB Toshiba drive, in all its glory. We have a feeling that it's going to be super-easy to upgrade this drive to 500GB...
Image #1
Add Note Edit Step 6  ¶
  • Remove the three T8 security Torx screws on the underside of the PS3 slim.
  • What's that, you say? Security screws? Yes, that's right. These screws have a pin in the center of them that prevents an ordinary Torx screwdriver from working. These screwdrivers are widely available, just not quite as easy to come by as a normal Torx.
  • Sony did this to prevent people like us from taking it apart.
  • Those three T8 security Torx screws seem to be the only non-Phillips head fasteners on the entire device.
  • This seems a little spiteful-- hardware hacking is a fine American tradition. No worries, we'll make sure it's easy for you to get these screwdrivers.
Image #1 Image #2
Add Note Edit Step 7  ¶
Image #1
Add Note Edit Step 8  ¶
  • Seven Phillips screws need to be removed from the bottom.
  • Interestingly enough, the rubber pad on the front-right corner of the PS3 has no screw hidden underneath it. Imagine our surprise when we removed it!
Next » « Previous
Required Tools
Spudger
$2.95 · 50+ In stock
Phillips #1 Screwdriver
$4.95 · 27 In stock
T8 Torx Security Bit Screwdriver
$6.95 · 50+ In stock
Recommended Tools
Universal Drive Adaptor
$29.95 · 50+ In stock
iFixit Lock Pick Set
$29.95 · 9 In stock
Inspection Scope
$39.95 · 37 In stock
Frictionless Ratchet
$24.95 · 47 In stock
Portable Anti-Static Mat
$24.95 · 15 In stock
Popular Device Products
