PlayStation 2 Teardown
Teardown
Teardown
Teardowns provide a look inside a device and should not be used as disassembly instructions.
User-Contributed Guide
This guide will show you how to take your PlayStation 2 apart, down to the bare bones.
Image #1 Image #2 Image #3
Add Note Edit Step 1 — PlayStation 2 Teardown  ¶
  • Flip the Playstation 2 (PS2) so that the bottom of the device is facing up.
  • Using a metal splunger pry the 8 flat screw covers out.
  • Remove the following 8 screws:
    • Four 55.4mm Philips head screws.
    • Four 18mm Phillips head screws.
Image #1
Add Note Edit Step 2  ¶
  • Peel away the warranty sticker. It is located right next to the main power switch. Please note removing this sticker will void your warranty but many factory warranties on PlayStation 2 systems have run out since the systems are so old.
Image #1 Image #2
Add Note Edit Step 3  ¶
  • Flip the PS2 back over and remove the top cover, prying the half closer to the power switch first and rocking the whole thing towards the front.
  • Carefully remove the cord that attaches the two halves by unclipping the power cord assembly from the case in the lid.
Image #1 Image #2
Add Note Edit Step 4  ¶
  • Remove the four 6.4mm Phillips head screws which hold the lid of the disc drive on.
  • Remove the lid.
Image #1 Image #2
Add Note Edit Step 5  ¶
  • Remove the two 6.4mm #00 Phillips head black screws holding the disc drive in place.
  • Remove the whole disc drive by carefully tilting the lid and sliding out.
Image #1 Image #2
Add Note Edit Step 6  ¶
  • Remove two 14.6mm Phillips head gold screws to remove controller port.
Image #1 Image #2
Add Note Edit Step 7  ¶
  • Gently lift out the controller port.
  • Remove the ribbon cable.
Image #1
Add Note Edit Step 8  ¶
  • Remove two 14.6mm Phillips head gold screws holding the fan.
Next » « Previous
Required Tools
Phillips #00 Screwdriver
$4.95 · 50+ In stock
Phillips #1 Screwdriver
$4.95 · 5 In stock
Metal Spudger
$2.95 · 5 In stock
Recommended Tools
Universal Drive Adapter
$29.95 · 50+ In stock
Inspection Scope
$39.95 · 17 In stock
Portable Anti-Static Mat
$24.95 · 11 In stock
Popular Products
Unibody Laptop Dual Drive
$39.95 · 3 In stock
iPad 2 Bluetooth/Wi-Fi Antenna
$24.95 · 2 In stock
iPad 2 Adhesive Strips
$6.95 · 47 In stock
iPhone 4S Display Assembly
$94.95 · 5 In stock
