PlayStation 2 Teardown
Teardown
Teardown
Teardowns provide a look inside a device and should not be used as disassembly instructions.
Student-Created Guide
An awesome student from our education program made this guide. It is not managed by iFixit staff.
This guide will show you how to take your PlayStation 2 apart, down to the bare bones.
Image #1
Edit Step 1 PlayStation 2 Teardown  ¶
  • Flip the Playstation 2 (PS2) so that the bottom of the device is facing up.
  • Using a metal splunger pry the 8 flat screw covers out.
  • Remove the following 8 screws:
    • Four 55.4mm Philips head screws.
    • Four 18mm Phillips head screws.
Image #1
Edit Step 2  ¶
  • Peel away the warranty sticker. It is located right next to the main power switch. Please note removing this sticker will void your warranty but many factory warranties on PlayStation 2 systems have run out since the systems are so old.
Image #1
Edit Step 3  ¶
  • Flip the PS2 back over and remove the top cover, prying the half closer to the power switch first and rocking the whole thing towards the front.
  • Carefully remove the cord that attaches the two halves by unclipping the power cord assembly from the case in the lid.
Image #1
Edit Step 4  ¶
  • Remove the four 6.4mm Phillips head screws which hold the lid of the disc drive on.
  • Remove the lid.
Image #1
Edit Step 5  ¶
  • Remove the two 6.4mm #00 Phillips head black screws holding the disc drive in place.
  • Remove the whole disc drive by carefully tilting the lid and sliding out.
Image #1
Edit Step 6  ¶
  • Remove two 14.6mm Phillips head gold screws to remove controller port.
Image #1
Edit Step 7  ¶
  • Gently lift out the controller port.
  • Remove the ribbon cable.
Image #1
Edit Step 8  ¶
  • Remove two 14.6mm Phillips head gold screws holding the fan.
Image #1
Edit Step 9  ¶
  • Remove the cover for the Expansion Bay.
    • If you utilize your expansion bay for its intended purpose, make sure you remove the component now.
  • Pull the inards out and away from the bottom cover.
  • Now that all of that bulky plastic is out of the way, we can get to the fun stuff - electronics!
  • Let's begin by removing the four 7.6mm Phillips head gold screws holding on the power supply board.
Image #1
Edit Step 10  ¶
  • With the screws out of the way, the metal case that houses the expansion bay will lift off with ease.
  • There is one cable that is clipped onto the power board. It is located next to the main power switch.
    • Carefully begin lifting the power board. You can now see the clip holding the power board in place.
  • Unsnap the clip, and the board is free from the unit.
Image #1
Edit Step 11  ¶
  • Underneath where the power supply once was is a transparent piece of plastic. This is the heat shield, and it can now be removed.
  • It can be a bit stubborn, so it may take a little finessing to get it free.
Image #1
Edit Step 12  ¶
  • Now with the heat shield out of the way, you can see there are quite a few screws holding the rest in place.
  • First, remove the seven 5.8mm Phillips head silver screws.
  • Next, take out the two 7.4mm Phillips head gold screws.
Image #1
Edit Step 13  ¶
  • We can now remove the fan and main power switch assembly.
    • Remove the small white piece of tape that holds the wire connected to the fan.
    • Unplug the wire from the logic board.
    • The fan and switch are now free from the rest of the PS2. Simply remove it by pulling it out the bottom.
Image #1
Edit Step 14  ¶
  • Unclip flaps, one on one side and two on the other, holding the disc drive together. The first two pictures display where the three flaps are. This is very tricky so take your time.
  • Carefully begin to lift out the disc drive. Beware, there are ribbon cables still attached.
Image #1
Edit Step 15  ¶
  • There are four ribbon cables attached to the disc drive. Be careful not to rip any of them!
    • Remove the three blue ribbon cables and one little orange cable by gently pulling on the blue plastic strips.
    • Carefully remove the orange ribbon cable from the laser by gently pulling on the white plastic strip.
Image #1
Edit Step 16  ¶
  • After the disc drive has been completely removed flip it over.
  • Gently lift off the metal cooling fins.
  • All that remains in view should be the logic board.
Image #1
Edit Step 17  ¶
  • This is what your disassembly should look like when finished.
Required Tools
Phillips #00 Screwdriver
$5.95 · 50+ In stock
Phillips #1 Screwdriver
Metal Spudger
$2.95 · 50+ In stock
Recommended Tools
Universal Drive Adapter
$29.95 · 50+ In stock
iFixit Lock Pick Set
Inspection Scope
$39.95 · 50+ In stock
Frictionless Ratchet
$24.95 · 50+ In stock
Portable Anti-Static Mat
$34.95 · 39 In stock
Popular Products
iPhone 4S Dock Connector
$34.95 · 50+ In stock
iPhone 5 Rear Camera
Small Suction Cup
Essential Electronics Toolkit
Anti-Static Wrist Strap
$7.95 · 50+ In stock
Comments Comments are onturn off
mine is from 2001 so i took off the seal crelessley
Nick, · Reply
Today: 2
This Week: 18
This Month: 276
All Time: 24,059
