Image #1 Image #2
Add Note Edit Step 9  ¶
  • The four motors and their electronic controllers are each held to the central cross by six screws and a connector.
  • Each brushless motor runs at 28,000 RPM while the AR.Drone is hovering, and as fast as 41,400 during full acceleration.
  • The speed of the motor is managed by the electronic controller, which includes an 8-bit microcontroller and a 10-bit ADC.
Image #1 Image #2
Add Note Edit Step 10  ¶
  • The arduous task of peeling the protection blister from the body reveals the camera ribbon cable and the second magnet that holds the hull in place.
Image #1 Image #2
Add Note Edit Step 11  ¶
  • A little bit of prying and the front-facing VGA camera comes right off.
  • The 93 degree wide-angle camera can stream its video and images directly to your iPhone, iPad, or iPod Touch.
  • With a resolution of 640x480 pixels, we doubt anyone will be filming HD movies with the AR.Drone's camera.
  • With Augmented Reality, objects captured by the camera become part of the AR.Flying Ace game.
Image #1 Image #2
Add Note Edit Step 12  ¶
  • The central cross easily pulls right out of the foam shell.
  • The two sets of wires in the central cross are responsible for controlling and providing power to the four motors.
  • The tubes of the cross are made of carbon fiber to save weight and provide plenty of structural rigidity.
  • The other plastic pieces are made of polyamide 6,6 (PA66), more commonly known as nylon.
    • Yes, there are different variations of nylon, but it's not necessary to explain the differences between condensation and open-ring polymerization right now. Let's just get back to tearing down the AR.Drone.
Image #1 Image #2
Add Note Edit Step 13  ¶
  • Parrot AR.Drone Repairability: 9 out of 10 (10 is easiest to repair).
    • The battery and upper case come off easily without removing a single screw.
    • Almost everything is attached via ribbon cable connectors and screws, making replacement much more feasible.
    • Parrot provides replacement parts and repair videos for common problems. Repair wouldn't be very easy without both of these.
    • The c-clips on each propeller assembly are very hard to remove without the correct tool.
    • It's a pain to reapply adhesive after removing all the adhered parts.
Next » « Previous
Required Tools
Spudger
$2.95 · 50+ In stock
T6 Torx Screwdriver
$4.95 · 50+ In stock
Recommended Tools
Universal Drive Adaptor
$29.95 · 50+ In stock
iFixit Lock Pick Set
$29.95 · 15 In stock
Inspection Scope
$39.95 · 38 In stock
Frictionless Ratchet
$24.95 · 48 In stock
Portable Anti-Static Mat
$24.95 · 16 In stock
Popular Products
iPhone 4S Replacement Battery
iPhone 5 Liberation Kit
$9.95 · 22 In stock
Anti-Static Wrist Strap
$7.95 · 50+ In stock
Pro Tech Toolkit Expansion 1
$79.95 · 9 In stock
Helping Hands
$8.95 · 50+ In stock
