Panasonic EB TX320ASW Teardown
Teardown
Teardown
Teardowns provide a look inside a device and should not be used as disassembly instructions.
Grammatical Errors
Grammatical Errors
This guide has grammatical errors or does not meet iFixit's writing guidelines.
Incorrect Bullets
Incorrect Bullets
This guide contains bullet colors that do not match markup, or improperly-used bullet types.
User-Contributed Guide
This guide is not managed by iFixit staff.
  • Add Note x
In this tutorial we will show you a breakdown of the Panazonic EB TX320. By using this guide, a user will be able to properly take apart their phone and replace any broken components.
first image
thumb image 1
thumb image 2
Add Note Edit Step 1 — Panasonic EB TX320ASW Teardown  ¶
  • To remove the faceplate, pry the top of faceplate away from the phone. Follow snaps down, until faceplate is completely popped off.
first image
Add Note Edit Step 2  ¶
  • To remove battery push clip in; battery will pop out.
first image
Add Note Edit Step 3  ¶
  • Using a Star 3.0 bit, remove 4 screws in battery compartment.
first image
thumb image 1
thumb image 2
Add Note Edit Step 4  ¶
  • To separate front of phone from the back; start prying from bottom and work up the side. The phone should then pop apart.
first image
Add Note Edit Step 5  ¶
  • To remove keypad, turn front of phone over and let keypad fall out. All keys are connected by one rubber section.
  • If a button had been ripped off your keypad, you can replace the entire rubber keypad at this step and reassemble phone.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 6  ¶
  • To remove main-board from phone grab side of phone and pry upwards. Board should snap out.
first image
Add Note Edit Step 7  ¶
  • To remove speaker cover, pull out silver plate.
first image
thumb image 1
thumb image 2
Add Note Edit Step 8  ¶
  • After silver plate is removed, power button sits freely. Speaker can be removed by pulling up on it.
  • If your speaker went out it can easily be replaced in this step with a new one, then reassemble phone after this step.
first image
thumb image 1
thumb image 2
Add Note Edit Step 9  ¶
  • To remove keyboard circuit press on the middle and slide down. The board will pop up allowing for removal.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 10  ¶
  • To remove main-board from bracket, gently apply pressure to the four small clips. Board will pop out freely.
first image
thumb image 1
thumb image 2
Add Note Edit Step 11  ¶
  • To remove LCD screen pry back on highlighted clip and pull screen out. The screen will then pull up and out.
  • If the LCD screen went out, or was cracked somehow, replace with a new LCD screen and then reassemble phone from this step.
