Page 1 of 1
Nintendo Family Computer (Famicom) Teardown
Teardown
Teardowns provide a look inside a device and should not be used as disassembly instructions.
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
It's day four of our week of game console teardowns. We stole borrowed a hot tub time machine, went directly to 1983, and acquired a Japanese national treasure: the Famicom!
We partnered with Wired for this teardown to bring you a glimpse of one of the most popular game consoles ever. Check out their story!
For those of you born in this century, the Famicom -- short for Family Computer -- is the name of the Nintendo Entertainment System (NES) in Japan. Join us as we delve into the system that revolutionized the gaming world as we know it.
- View:
- Paginated
- Full width
Edit Step 1
Our contestant hails from a mystical place, the land of the rising sun, Japan!
The Nintendo Family Computer, released in 1983 in most of Asia, is the overseas brother of the Nintendo Entertainment System.
Technical Specifications:
Ricoh 2A03 8-bit 1.79 MHz processor (based on the MOS Technology 6502 8-bit processor core)
2KB (16Kb) on-board RAM
2KB (16Kb) on-board Video RAM
PSG Sound
256 x 240 pixels resolution
Edit Step 3 ¶
Fully assembled Nintendo Famicom console.
The Famicom was the first console to popularize D-pad controllers to acquire user input. Departing from the era of joysticks, the inclusion of the D-pad allowed for quick and accurate controls.
The controllers are similar, but not the same...
The first controller boasts the traditional layout: D-pad on the left, "select" and "start" buttons in the center, and "b" and "a" buttons on the right.
However, the second controller has a built-in microphone and a volume switch at the expense of the central "select" and "start" buttons... Cool!
This is the only console we know of that has a microphone on one of its standard controllers.
Edit Step 6 ¶
Two antiquated connectors exchange signals between the controllers and the board.
Want to disconnect a controller? Gotta remove the bottom cover -- but that's pretty much it.
Controller II has an extra wire for microphone input and controlling the volume.
After disconnecting them from the board, the controller cables can be lifted out of the case.
Edit Step 8 ¶
Notable chips on the board include:
Ricoh RP2A03G 8-bit, 1.79 MHz CPU
Ricoh RP2C02G-0 8-bit, 5.32 MHz PPU
Toshiba TC40H368P hex bus buffers
Sharp LH5216D-12 static RAM
Hitachi HD74LS139P decoder/demultiplexer
Fujitsu MB74LS373
Unsurprisingly, lead solder abounds on the bottom of the board. RoHS standards weren't established until 20 years after this puppy was made.
Edit Step 9 ¶
Well hello there!
"Shall I compare thee to an Xbox 360? Thou art more lovely and more temperate...But thy internal structure shall not fade...Nor shall time brag thou wand'rest in its shade...So long as gamers can breathe or eyes can see, So long lives this, and this gives life to thee."
Edit Step 10 ¶
After the motherboard assembly is out, the reset and power button covers can easily be removed.
Unclipping a spring is all that's needed to remove the eject mechanism from the outer case.
Ejecting a cartridge is accomplished by pushing two inclined planes underneath the cartridge until it pops up off the connector attached to the board.
Edit Step 11 ¶
BreakingGently releasing the retaining clips holding the cartridge together reveals a 60 pin printed circuit board.Front and back sides of the Famicom cartridges:
This PCB from a Tennis cartridge has two ROM packages -- totaling 24 KB -- soldered to one side.
For comparison, a single layer Blu-ray disc has a 25,000,000 KB capacity.
Edit Step 12 ¶
And there you have it - the Famicom in pieces.
Be sure to keep an eye on our teardown page for an inside-look at all the latest gadgets.
We're sad to say that we don't have parts for the Famicom, but we do have a brand new game console parts store to help keep your (slightly more modern) consoles running.
Keep an eye on our teardown page or blog for a detailed look at another retro game console tomorrow!
Page 1 of 1
