first image
thumb image 1
thumb image 2
Add Note Edit Step 9  ¶
  • The Wi-Fi board is held in place via one large connector. A quick wedge-and-twist action of the spudger releases it from the main board.
  • Another flick of the spudger removes the Wi-Fi board's connector wire.
first image
thumb image 1
thumb image 2
Add Note Edit Step 10  ¶
  • The main board comes off almost as easily as the battery PCB:
    • Four Phillips screws need to be removed.
    • Six connectors need to be disconnected prior to removal: five on the visible side, and one on the other side.
first image
Add Note Edit Step 11  ¶
  • We are done with the first level of the disassembly.
first image
thumb image 1
thumb image 2
Add Note Edit Step 12  ¶
  • Four black plastic covers need to be removed to reveal the Phillips screws underneath.
  • Removing the four Phillips screws allows access to the top display.
first image
thumb image 1
thumb image 2
Add Note Edit Step 13  ¶
  • The upper half with outer case removed.
  • The antenna board for Wireless LAN is mounted in the upper right corner of the chasis.
  • The ribbon cables for the top display and cameras are coiled and routed through the hinge between case halves. We'll go ahead and add that to the list of parts we want to watch a robot assemble.
  • The thin orange wire seen in the second photo is for the microphone. Little DJs everywhere will drool over a new feature allowing users to distort the pitch and speed of music during playback.
first image
Add Note Edit Step 14  ¶
  • The DSi has two VGA CMOS digital cameras (0.3 megapixels); one on the internal hinge pointed towards the user and the other in the outer shell.
first image
thumb image 1
thumb image 2
Add Note Edit Step 15  ¶
  • Eight Phillips screws secure the battery compartment and the stylus tray/SD/SDHC expansion slot to the case.
  • The DSi has an integrated SD/SDHC expansion slot. You can now use a normal SD card for the playback of AAC audio files and external storage of pictures or downloaded software. Can anyone say homebrew apps?
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 16  ¶
  • The logic board in its full glory.
  • Chips of interest, left to right:
    • Samsung 1st generation MoviNAND KMAPF0000M: 256 MB NAND Flash and MMC controller. The integrated MMC controller allows the CPU to offload the complex work of directly talking to the flash memory.
    • 82DBS08164D-70L: Fujitsu Ltd 128-bit FCRAM (fast-cycle RAM) chip.
    • Nintendo's custom ARM CPU. Our CPU was manufactured in September of 2008.
Next » « Previous
Popular Products
iPhone 3GS Display Assembly
$99.95 · 13 in stock
1.5" Thin Putty Knife
$4.95 · 50+ in stock
Flathead 3/32" or 2.5 mm Screwdriver
Metal Spudger
$2.95 · 50+ in stock
Notes Add Note Notes are offturn on
