first image
thumb image 1
thumb image 2
thumb image 3
Add Note Step 9
  • The display is attached to the metal shield by several fingers that apply pressure between the shield and the edge of the display.
  • Flip back the ZIF cable lock and remove the display.
  • Use an iPod opening tool to pop the speaker assembly out of the metal shield.
  • The speaker pumps out some pretty fresh beats when the camera is in projector mode.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Step 10
  • Remove a few screws around the perimeter of the open back of the camera.
  • After some (careful) prying, the top and right covers pop right off.
  • Interestingly, the controls along the top of the camera are attached to a board below the top cover. The top cover just houses the button covers.
first image
thumb image 1
thumb image 2
Add Note Step 11
  • Carefully lift the protective steel panel to reveal the logic board.
  • Use the tip of a spudger to flip back the ZIF cable lock to disconnect the control ribbon cable before removing the panel.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Step 12
  • Pry the upper camera cable connector straight up off the logic board.
  • Flip back the ZIF cable lock and remove the lens assembly.
  • Copper was an interesting choice for the rear cover of the lens assembly.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Step 13
  • The camera module in all its glory.
  • Like most compact digital cameras with optical zoom that have no externally telescopic lenses, the S1000pj's internal zoom lenses move perpendicular to the front face.
  • The basic components include:
    • A few movable lenses.
    • CCD image sensor.
    • Optical zoom motor and feedback sensor to position the lenses.
    • Aperture and image stabilization modules.
  • Light has to travel through at least four glass lenses until it shines on the CCD sensor. What a journey.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Step 14
  • We had to disconnect a few additional ZIF cables and remove some screws still securing the the logic board to the main chassis.
  • Disassembling this camera is not for the faint of heart -- Nikon definitely did not intend this device to be user serviceable.
  • We even had to de-solder a bunch of components including the camera cover actuator, projector LED, and flash bulb.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Step 15
  • To remove the projector lens, first remove the flash tube.
  • After removing a few screws...
  • ...The projector assembly lifts right out.
first image
Add Note Step 16
  • Here's an inside look at the projector assembly sans the protective cover.
  • Light for projecting images is supplied by a very powerful LED (shown in red) that even has its own heat sink to conduct heat to the aluminum front panel.
  • As light leaves the LED it passes through some filters and lenses (shown in orange).
  • A good deal of engineered optical reflection allows the light emitted by the LED to reflect through a tiny LCD panel (shown in yellow) and head toward the mirror.
  • Before bouncing off the angled mirror and exiting the camera, the projected image passes through a focusing lens (shown in blue) connected to the slider on the top panel.
Add NoteNotes: Step 16
Flag Reply by Lummi Oct 6 @ 12:55 PM
I love this web site, fantastic idea.
I wonder what high power LED they are using?
Flag Reply by kadoong Oct 25 @ 9:02 PM
Quote from Lummi:
I love this web site, fantastic idea. I wonder what high power LED they are using?
Me too. I really wonder what high power LED used.
