first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 9  ¶
  • Removing the logic board:
  • Remove the power supply connector. Just lift it straight up, and it should come free.
  • remove this screw.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 10  ¶
  • Lift the end of the logic board(away from the ports), and slide it away from the ports.
  • Now, set the board aside.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 11  ¶
  • Power Supply:
  • Remove this screw.
  • Lift the power supply up, and out.
first image
Add Note Edit Step 12  ¶
  • The Logic Board Overview:
  • The Board has a 25Mhz Motorola 68040 CPU, This board features a ton of chips for somthing made nearly 20 years ago.
  • The CPU: Motorola XC68040RC25
  • The Co-Procesor: MB610313
  • Motorola Chips
  • Intel Chips
  • AMD Chips (Intel and AMD In the same computer?)
  • Fujitsu Chips
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 13  ¶
  • Made in the USA, you don't see this anymore.
  • The Serial #
  • Looks like my NeXTStation came from WilTel.
  • It is model # N1100
Next » « Previous
Required Tools
Phillips #0 Screwdriver
$4.95 · 50+ in stock
Recommended Tools
Home Tech Toolkit
$24.95 · 50+ in stock
Sorting Tray
$7.95 · 50+ in stock
Anti-Static Wrist Strap
Pro Tech Base Toolkit
$59.95 · 50+ in stock
Thirsty Bag
$6.95 · 50+ in stock
Popular Products
iPhone 4S Rear Glass Panel
$79.95 · 16 in stock
iPhone 3G Replacement Battery
$14.95 · 50+ in stock
$2.95 · 50+ in stock
96 Piece Security Bit Set
Precision Tweezers Set
$7.95 · 28 in stock
Notes Add Note Notes are offturn on
