Motorola Droid 3 Teardown
Teardown
Teardown
Teardowns provide a look inside a device and should not be used as disassembly instructions.
The Motorola Droid 3 has landed on our doorstep, and no new gadget would be complete without a proper iFixit teardown.
Follow iFixit on twitter for the latest updates.
Image #1 Image #2
Add Note Edit Step 1 — Motorola Droid 3 Teardown  ¶
  • After various upgrades and special editions of the Droid 2, its successor has finally arrived! The third Droid to hail from the halls of Motorola is appropriately named "Droid3," or more officially, the Droid 3.
  • With almost two years since the launch of the first Droid, Motorola has had plenty of time to load the Droid 3 with some impressive tech specs.
    • Android 2.3 OS (Gingerbread)
    • Dual-Core 1GHz processor
    • 5-Row full QWERTY keyboard
    • 8 MP Camera with 1080p video capture
    • 4" 960 x 540 qHD display with Gorilla Glass
Image #1 Image #2 Image #3
Add Note Edit Step 2  ¶
  • Motorola advertises that the Droid 3 is the "Thinnest Full QWERTY Smartphone Ever."
    • When compared to the original Droid, it is clear that the Droid 3 is smaller. However, the thickness difference is hardly something to brag about.
  • The rear-facing camera on the Droid 3 includes an LED flash and 8x zoom capability.
  • The Droid 3 features both micro USB and micro HDMI ports, allowing for full 1080p output to any compatible device.
    • The port layout on the left side gives the Droid 3 an uncanny resemblance to the Motorola Atrix.
Add Note Edit Step 3  ¶
  • Pulling off the back cover gives us our first glimpse at the user-replaceable battery.
  • Motorola claims that the battery inside the Droid 3 will last for over 9 hours of continuous talk time, or over 300 hours of continuous stand-by time.
    • We suspect, however, that having the phone in standby for 300 hours would be very, very boring.
  • The battery is rated at 3.7 V and 1540 mAh.
Add Note Edit Step 4  ¶
  • Whoa! This Droid has a SIM card!
    • CDMA, the network protocol for Verizon, does not require SIM cards.
  • A lack of SIM cards severely hampered international use of Verizon's network. This SIM will enable the Droid 3 to be used almost anywhere in the world.
    • For a more complete explanation of Verizon, CDMA, SIM cards, and other, similar things, check out our Verizon iPhone Teardown.
  • A very attention-grabbing informational card included with the phone is neon orange for a reason. For some regions outside the USA, data charges might be as high as $20.48 per MB!
Add Note Edit Step 5  ¶
  • Like its predecessors, the Droid 3's rear case is held in place by a few T5 Torx screws.
  • Motorola likes to hide screws and latches beneath the information label, making opening the phone a rather sticky affair.
  • With the screws unscrewed, the clips unclipped, and the stickers unsticked, we get a full-on exposè of the Droid 3's innards.
Add Note Edit Step 6  ¶
  • Next, we use a plastic opening tool to lift the camera ribbon cable off its socket on the motherboard.
  • The Droid 3 is equipped with an 8 MP rear-facing camera capable of recording 1080p video at 30 fps.
Add Note Edit Step 7  ¶
  • Adiós motherboard screws, we hardly knew you...
  • After removing a few more connectors, the motherboard easily lifts off the phone.
  • In order to strip the motherboard bare, the speaker/antenna assembly must be pried off of the board.
  • The speaker assembly uses pressure contacts to transmit data to both the speaker and the antenna. Interestingly, a hole through the motherboard allows sound to pass through for better transmission to the outside of the phone.
Image #1
Add Note Edit Step 8  ¶
  • The main ICs on the front side of the motherboard include:
    • Qualcomm MDM6600 supporting HSPA+ speeds of up to 14.4 Mbps
    • SanDisk SDIN4C2 16GB MLC NAND flash
    • Elpida B4064B2PB-8D-F 512MB RAM and TI OMAP 4430 CPU
    • Triquint TQM7M5013 Linear Power Amplifier
    • Avago A2F1106
    • A5005 K1116, A5002 K1118, A5001 K1118 (from bottom to top)
    • Kionix KXTF9 11425 1411 three-axis accelerometer
Next » « Previous
Required Tools
Spudger
$2.95 · 50+ In stock
T5 Torx Screwdriver
$6.95 · 50+ In stock
T3 Torx Screwdriver
$9.95 · 34 In stock
Plastic Opening Tools
Recommended Tools
Universal Drive Adaptor
$29.95 · 50+ In stock
iFixit Lock Pick Set
$29.95 · 30 In stock
Inspection Scope
$39.95 · 40 In stock
Frictionless Ratchet
$24.95 · 49 In stock
Portable Anti-Static Mat
$24.95 · 19 In stock
Popular Products
iPad 2 Front Panel
$94.95 · 50+ In stock
iPad Retina Front Panel
Phillips #00 Screwdriver
$4.95 · 50+ In stock
Small Suction Cup
