Motorola California Mobile Phone Teardown
Teardown
Teardown
Teardowns provide a look inside a device and should not be used as disassembly instructions.
Incorrect Tools
Incorrect Tools
Help make this guide better by using the correct tools in images and/or text.
Needs More Images
Needs More Images
A few more images would make this guide's procedures crystal clear.
Missing Prerequisites
This guide is missing information on how to start the process. Make a prerequisite guide!
User-Contributed Guide
Better Introduction
Better Introduction
Improve this guide by completing or revising its introduction.
Image #1
Add Note Edit Step 1 — Motorola California Mobile Phone Teardown  ¶
  • Remove the battery by sliding it down the rails to which it is connected.
Image #1
Add Note Edit Step 2  ¶
  • Find a flat head or Phillips head screwdriver.
  • Insert the screwdriver into the holes in the plastic rod connecting the key pad guard to the rear casing.
  • Use the screwdriver to push the rods towards each other until they click out of their locked position.
  • Note: This may require a large amount of force.
Image #1
Add Note Edit Step 3  ¶
  • Slide off the antenna guard and locate the four clips on the exterior of the rear casing.
  • Simultaneously push the clips outward while lifting the rear casing and keyguard away from the front casing.
  • Remove the key guard from the rear casing by taking it out of its position.
Image #1
Add Note Edit Step 4  ¶
  • Locate and unplug the black component of the antenna from the motherboard.
  • Under the black component should be a blue component. Unscrew this component in order to free the antenna.
Image #1
Add Note Edit Step 5  ¶
  • Slide the antenna out of the green tubing and slide the green tubing out of it's corresponding hole on the motherboard.
Image #1
Add Note Edit Step 6  ¶
  • Lift the motherboard out of its location in the front casing.
  • Do this slowly and gently so that none of the motherboard's components are damaged.
Popular Products
iPhone 4S Dock Connector
$34.95 · 50+ In stock
Metal Spudger
$2.95 · 50+ In stock
Small Suction Cup
T8 Torx Security Bit Screwdriver
$6.95 · 50+ In stock
