Edit Step 14 ¶
Removing the Heatsinks.
The Big one to the right, is the CPU, the smaller one to the left is for the GPU.
Lift the black tab up on the cpu heatsink. this will release the tension on the chip.
Then use a flathead screwdriver to remove the clip. Then Lift the CPU heatsink out (this may take some force)
Edit Step 15 ¶
The CPU
So What's Under Door Number One?
An Intel Pentium III CPU running at 733Mhz.
This is actualy a surprise, because almost every other console out there uses an IBM PowerPC CPU, this makes us wonder, could this console emulate windows?
It also raises the question, why did Microsoft Switch to PowerPC, around the same time Apple switched to Intel?
Edit Step 16 ¶
The GPU
Push on the tab on the GPU Heatsink, While doing this, use a flathead screwdriver to push on the tab, so when released, it clears the latch
Be Careful, if you break any one of these tabs, then, your heatsinks will not be usable, and your console will fry, if you try to run it.
Removing the GPU heatsink, revealls a NVIDIA Custon Chip.
Page 2 of 3
