Xbox Teardown
Teardown
Teardown
Teardowns provide a look inside a device and should not be used as disassembly instructions.
Featured Guide
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
User-Contributed Guide
This guide is not managed by iFixit staff.
  • Add Note x
The Original Xbox was one of the best selling game consoles of all time, it had amazing graphics compared to the Playstation 2, the Nintendo Gamecube, and the Nintendo 64. Now, lets take a look inside...
first image
thumb image 1
thumb image 2
Add Note Edit Step 1 — Xbox Teardown  ¶
  • The Xbox, Not as Pretty as it was when I bought it 7 years ago.
first image
thumb image 1
thumb image 2
Add Note Edit Step 2  ¶
  • To begin dissasembly, flip the console so it is upside-down.
  • Remove the 4 Rubber Pads with a flathead screwdriver, or a heavy duty spudger. It takes a little force to get them off.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 3  ¶
  • Doing this should reveal 4 T10 Torx Screws, But, there are 2 More hidden by stickers.
  • The other 2 are shown in yellow.
  • Removing the 2 screws hidden by stickers will void your warrenty, even though, I'm sure that your warrenty has already expired.
first image
thumb image 1
thumb image 2
Add Note Edit Step 4  ¶
  • Removing the 6 T10 Screws.
  • Hmm, where heve we seen these before?
  • My Xbox 360 Teardown, of course!
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 5  ¶
  • To remove the top half of the console, flip it upright, and use a flathead screwdriver to seperate the two halves.
first image
thumb image 1
thumb image 2
Add Note Edit Step 6  ¶
  • Simply lift the top half off.
  • This reveals the drives.
  • From Left To Right: The DVD-ROM Drive, And A Seagate 8GB Parallel ATA Drive
first image
thumb image 1
thumb image 2
Add Note Edit Step 7  ¶
  • Removing The Drives
  • Start By removing the ATA Cable from both drives. There might be a piece of double sidded tape holding the ribbon cabble in place.
first image
thumb image 1
thumb image 2
Add Note Edit Step 8  ¶
  • Then Remove the power cables from the drives.
  • The Hard Drive Uses Standard Power Adaptor, but the DVD-ROM drive, uses a proprietary xbox connector similar to that of the xbox 360.
Next » « Previous
Required Tools
T8 Torx Security Bit Screwdriver
$6.95 · 47 in stock
Flathead 3/32" or 2.5 mm Screwdriver
$4.95 · 50+ in stock
T10 Torx Screwdriver
Heavy-duty Spudger
6-in-1 Screwdriver
$4.95 · 3 in stock
Recommended Tools
Home Tech Toolkit
$24.95 · 50+ in stock
Sorting Tray
$7.95 · 50+ in stock
Anti-Static Wrist Strap
Pro Tech Base Toolkit
$59.95 · 50+ in stock
Thirsty Bag
$6.95 · 50+ in stock
Popular Products
iPhone 3G and 3GS Power Button
Metal Spudger
$2.95 · 50+ in stock
Plastic Cards
Notes Add Note Notes are offturn on
