Edit Step 10 ¶
Removing the bottom half.
This next step is hard, but I promise that the bottom half comes off.
Using a small flathead screwdriver, pry these tabs apart. It's hard to show how to remove the clips, but you'll see soon enough.
Using a flathead screwdriver, pop out all 7 tabs. It's hard to do this without causing some damage to the casing.
Edit Step 15 ¶
Removing the DVD Drive.
It is a SATA DVD drive with a proprietary Xbox power connector.
Lift the drive up near the back revealing the connectors.
Remove both the power and SATA cables from the drive. Be careful when doing this, the connectors are fragile.
Pull the drive out of the console. There may be tape on the front of the drive holding it in, remove the tape.
Set the drive aside.
Page 2 of 3
