Microsoft Kinect Teardown
Teardown
Teardowns provide a look inside a device and should not be used as disassembly instructions.
The Kinect is a horizontal bar of sensors connected to a small base with a motorized pivot, and is designed to be positioned lengthwise below the video display.
Update: Video of our teardown is now up!
We picked up and tore down our Kinect on launch day -- November 4, 2010.
Tools (continued)
- View:
- Single page
Edit
Step 1
We finally have Microsoft's entrant into the realm of motion gaming, the Kinect. Microsoft's code name for Kinect was Project Natal.
This isn't just another Wiimote knockoff. Kinect is the result of hundreds of millions of dollars of research Microsoft has invested in speech and motion recognition.
The Kinect is not a handheld game controller like the Wiimote or the Playstation Move—rather, it is a sophisticated sensor suite that detects your position and movements in 3D space.
There are several great stories already out there explaining how Kinect detects motion. We aren't going to repeat all the basics here, so if you are interested in that sort of thing check out the above articles.
Edit
Step 2
Controller evolution, game console style.
Top to bottom:
Original Sony PlayStation controller, PlayStation Move.
We love that the world is at the point where we're not upgrading our computers as often. Instead, we're upgrading sensors so the computer understands more about us.
Adding Kinect to an Xbox is like adding sonar to a submarine—sure, you could drive it around before, but now it can see where it's going. OK, that's a rather stretched analogy. You get the idea.
Edit
Step 4
The plastic base is secured with a quartet of T6 Torx screws.
After removing the plastic base, there are another four Phillips #0 screws to remove.
Notice that Microsoft's already up to revision H. If this is launch day, what happened to revisions A through G?
Edit
Step 5
The Kinect's motor and gears don't appear too robust.
About the size of an American quarter, the base has a tiny motor with three fragile plastic gears. Barring overheating issues with the top unit, we're guessing this motor assembly will be the Kinect's weak point.
Do not physically force the Kinect into a specific position—allow it to automatically calibrate its aim.
Edit
Step 6
With a metal spudger and some pretty serious prying, we were able to remove the bottom grille. This is not easy, as Microsoft applied adhesive quite liberally.
The Microsoft team built the Kinect around PrimeSense's Reference Design.
Microsoft hasn't acquired Primesense yet. This indicates to us that as impressive as the hardware is, Microsoft's software is doing the heavy lifting, turning the sensor bar's array of data into a 3D mesh of your spatial position.
Edit
Step 7
Microsoft used T10 Torx security screws. That's not very nice. We're up to three types of screws already, and we haven't even got this open yet.
The innocent looking Xbox 360 sticker acts as cover for the third screw on each side of the Kinect.
Page 1 of 3
