Microsoft Surface Teardown
Teardown
Teardown
Teardowns provide a look inside a device and should not be used as disassembly instructions.
We got our hands on Microsoft's new Surface, and to its credit, it lasted a good twenty minutes before we decided to tear it open.
Ready for more than just a surface-level relationship? Follow us on Twitter or like us on Friendster 3.0.
Image #1 Image #2
Add Note Edit Step 1 — Microsoft Surface Teardown  ¶
  • Is that the display assembly from a PC laptop? Nope, it's the new Microsoft Surface with Windows RT.
  • Notable tech specs:
    • 10.6" ClearType HD Display (resolution of 1366x768 pixels)
    • Quad-core NVIDIA Tegra 3 processor
    • 2 GB RAM
    • 32 or 64 GB flash storage
    • Wi-Fi (802.11a/b/g/n) + Bluetooth 4.0
    • 720p HD Front and Rear facing LifeCams
Image #1 Image #2 Image #3
Add Note Edit Step 2  ¶
  • To give the Surface laptop-like connectivity, nearly every edge includes ports and buttons. They are (from left to right):
    • Magnetic charging, USB 2.0, and Micro-HDMI out on the right side
    • Magnetic connection for the Touch Cover or Type Cover on the bottom
    • Headphone jack and volume rocker on the left side
Image #1 Image #2
Add Note Edit Step 3  ¶
  • Just like your first big-kid bike, this laptop tablet comes with a kickstand to prop it up in notebook mode.
  • One of the most notable features of the Surface is its Touch Cover keyboard, which protects the screen when closed and provides a full QWERTY typing experience when open.
    • For users who find the Touch Cover to be too much a compromise, Microsoft offers the Type Cover, a chiclet keyboard that also folds up to protect the Surface's LCD.
Add Note Edit Step 4  ¶
  • We begin our expedition by removing the kickstand.
  • Fun fact: the kickstand is held in place by a few Torx screws.
  • Sans kickstand, we can easily view the markings on the back of the Surface's rear case. The Surface with Windows RT has a model number of 1516.
Add Note Edit Step 5  ¶
  • Small bezels tend to hide screws, so the first place we look to open the Surface is its long plastic camera cover.
  • Our pictures make it look easy, but removing this plastic cover took about half an hour and a lot of careful prying.
    • Chalk it up to inexperience. This step should take less than ten minutes once we create guides for it.
  • Not only did we find the screws we were searching for, but there is also what appears to be a tamper-evident seal that simply reads "Surface."
  • The tamper-evident label is composed of multiple sections. Unfortunately, it breaks apart upon removal.
Add Note Edit Step 6  ¶
  • After removing a total of 17 T5 Torx screws, (10 under the kickstand and 7 under the camera cover), the rear case comes right off—almost.
  • A lone ribbon cable still tethers the battery to a ZIF connector on the Surface's motherboard, which we make quick work of with the ever-trusty spudger.
Image #1 Image #2
Add Note Edit Step 7  ¶
  • The big question of the day: is the battery easily removed?
    • Answer: Yes. It's glued in, but it's way easier to remove than on the iPad. A couple of minutes of spudging around, and it's out.
  • We get our first look at the battery. As is the norm, the dual battery cell is adhered to the VaporMg rear case.
  • The 7.4 V, 31.5 Wh battery is manufactured by Samsung. It fits right in between the iPad 2's 25 Wh battery, and the iPad 3's 42.5 Wh unit.
Add Note Edit Step 8  ¶
  • Next we find a large orange ribbon cable leading to the "Apple-esque" magnetic charging port. The microSDXC card slot that hides underneath the kickstand is also attached to this ribbon cable. And not a single bother was given that day, so we proceeded to dismantle the speakers.
  • We love modular components inside tablets and smartphones, and these speakers fit that bill. A little bit of spudgering, and our Surface has gone silent.
    • With two speaker assemblies we are living in stereo.
Next » « Previous
Required Tools
Spudger
$2.95 · 50+ In stock
Heat Gun
$24.95 · 25 In stock
T5 Torx Screwdriver
$6.95 · 50+ In stock
T4 Torx Screwdriver
$4.95 · 44 In stock
Plastic Opening Tools
Recommended Tools
Universal Drive Adaptor
$29.95 · 50+ In stock
iFixit Lock Pick Set
$29.95 · 24 In stock
Inspection Scope
$39.95 · 39 In stock
Frictionless Ratchet
$24.95 · 48 In stock
Portable Anti-Static Mat
$24.95 · 17 In stock
Popular Products
Unibody Laptop Dual Drive
$39.95 · 50+ In stock
iPad Retina Front Panel
$94.95 · 50+ In stock
iPad 4th Gen Front Panel Assembly
$134.95 · 32 In stock
26 Bit Driver Kit
$19.95 · 43 In stock
