This teardown is not a repair guide. To repair your Mele F10, use our service manual.
  1. Mele F10 - USB Remote Teardown, Mele F10 - USB Remote Teardown: step 1, image 1 of 3 Mele F10 - USB Remote Teardown, Mele F10 - USB Remote Teardown: step 1, image 2 of 3 Mele F10 - USB Remote Teardown, Mele F10 - USB Remote Teardown: step 1, image 3 of 3
    • 2.4GHz wireless frequency
    • Max. control range: 30 meters
    • IR remote range: 10 meters
    • Built-in 500mAh battery
  2. Mele F10 - USB Remote Teardown: step 2, image 1 of 2 Mele F10 - USB Remote Teardown: step 2, image 2 of 2
    • There is no screws. I have opened remote only by hands by bendig edges
  3. Mele F10 - USB Remote Teardown: step 3, image 1 of 3 Mele F10 - USB Remote Teardown: step 3, image 2 of 3 Mele F10 - USB Remote Teardown: step 3, image 3 of 3
    • OK! let see what parts we have inside
    • nRF24LE1 - Ultra-low Power Wireless System On-Chip Solution
    • ADXL345 - small, thin, ultralow power, 3-axis accelerometer with high resolution (13-bit) measurement at up to ±16g
    • Two XV - 3700CB Ultra miniature size gyro sensor with high stability double output
    • IR TX diode
  4. Mele F10 - USB Remote Teardown: step 4, image 1 of 3 Mele F10 - USB Remote Teardown: step 4, image 2 of 3 Mele F10 - USB Remote Teardown: step 4, image 3 of 3
    • More parts
    • JTAG ?
    • Mini-USB port - as far as I know can be used only to charging
    • 500mAh battery
  5. Mele F10 - USB Remote Teardown: step 5, image 1 of 3 Mele F10 - USB Remote Teardown: step 5, image 2 of 3 Mele F10 - USB Remote Teardown: step 5, image 3 of 3
    • USB Receiver
    • nRF24LU1 - Single Chip 2.4 GHz Transceiver with USB Microcontroller and OTP Memory
Adam
128 Reputation
1 Guide authored
12 Comments
Super! Thank you
nisko84 - Reply
I Need to buy an IR replacement, could you please help me?
it is strange to me that you says it has a TX IR Diode, when the remote can also receive IR to "clone" the Signal from another remote.
thanks
Jose Manuel Peinado Navarro - Reply
it does not learn codes from Panasonic tvs (i tested) and from denon as i read here.
http://forum.mele.cn/showthread.php?tid=...
drdedus - Reply
Confirm not work with Panasonic TV
Aurel Enache -
I dropped the remote accidentally, now only works with the mini usb plugged in. any idea where and what to look for?
Thanks
Amine Elsemine - Reply
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 30
All Time: 12,451
