first image
thumb image 1
thumb image 2
Add Note Step 17
  • The logic board with all connectors removed.
  • Remove the following eight screws:
    • Six 3 mm Phillips from the logic board
    • Two 7.2 mm Phillips from the MagSafe board
  • Second image: removing logic board.
first image
Add Note Step 18
  • Top of logic board.
  • The speakers are mounted on the left next to the ports.
  • The heat sink covers the two NVidia chipsets and the processor.
  • This machine has 512 MB video memory for the NVidia 9600M. The 9400M chipset shares 256 MB of system memory. You have to log out to switch between graphics chipsets.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Step 19
  • Removing the black heat sink and heat conduit.
  • Second image: The processor and two NVidia chipsets revealed!
  • Intel processor: Intel 5831C024 SLGEL AV80576T9550 2.66 / 6M / 1066
  • No surprises there: 2.66 GHz, 6 MB L2 Cache, 1066 MHz bus, just as advertised.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Step 20
  • We removed the heat sink thermal compound so you can see the die markings.
  • Left image: Intel processor. No die markings!
  • Middle image: NVidia L901B138 0902B3 PB9487.000 MCP79MXT-B3
  • Right Image: NVidia 50N3BF 0850C1 NK6791.S1W NB9P-GS-W2-C1
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Step 21
  • Left: 15" Unibody logic board
  • Right: 17" Unibody logic board
  • What's different? The biggest difference to you is the additional USB port. Oh, and $800.
  • The low-end 15" board that we took apart in October only has 256 MB video memory (Samsung RAM soldered onto the board). The high-end 15" and this 17" have 512 MB video RAM.
  • High-resolution photo of the logic board.
first image
thumb image 1
thumb image 2
Add Note Step 22
  • The most famous upper case in the world, Apple's 'brick' CNC-manufactured Unibody case.
  • The second shot shows the speaker placement. We took the speakers out and put them on top of the case in the same position and orientation that they are internally.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Step 23
  • We removed the display assembly.
  • This photo is the 13", 15", and 17" MacBook displays stacked together. High resolution.
first image
Add Note Step 24
  • Clockwise from top left: Logic board, heat sink, display, unibody upper case, battery, hard drive, speakers. Fans, RAM, and optical drive are in the center.
  • There you have it! Be sure to check back often for more first looks, guides, and quality parts!
Add NoteNotes: Step 19
Flag Reply by jmwolgemuth Feb 17 2009 @ 2:34 PM
It looks like they weren't so messy with the thermal paste this time. ;)
Flag Reply by Industro Feb 17 2009 @ 2:55 PM
Are both speakers only on one side of the MacBook Pro?
Flag Reply by badmoon Feb 17 2009 @ 3:03 PM
Quote from Industro:
the second set of speakers should be under the DVD burner, the disassembly doesn't show It for now.
iFixit Staff
Flag Reply by Kyle Wiens Feb 17 2009 @ 3:26 PM
Quote from badmoon:
We added a photo on step 22 showing the speaker positioning.
Flag Reply by mobbarley Feb 17 2009 @ 11:42 PM
Any idea what the two components labeled with stickers ('Mac', 'Screen') are? They are to the left of the smaller gpu in the logic board shot.
Flag Reply by Nooway Feb 18 2009 @ 1:16 AM
What revision is the Firewire chip? They used rev: 6 of the bad Agere/Lucent one. I have read Apple has aknoweledged that there are some problems, and that there are a rev: 7 of the chip already out in some external cards. This could be very important for some firewire audio interfaces e.g. like the RME FireFace 800.
Flag Reply by wantsamac Feb 22 2009 @ 12:40 AM
Hi, is there a way to change out the nvidia 9400/9600 for a different chip, say a 8800 or 9800?
this is probably a really noob question but I had to ask
iFixit Staff
Flag Reply by steve Mar 6 2009 @ 2:09 PM
Quote from wantsamac:
Unfortunately, the video processor is soldered to the logic board and much too hard to replace without mechanized soldering tools.
Flag Reply by sillydrew Mar 11 2009 @ 4:24 PM
Hey is there a way to remove and put more ram on your logic board? Is that too difficult?
Flag Reply by svt May 3 2009 @ 9:45 PM
Can you power the logic board w/o the power button?
Flag Reply by Bastian Jan 30 @ 7:31 AM
Is there a special guide to change the (hardware) keyboard from qwerty to qwertz?
Bastian
Add NoteNotes: Step 20
Flag Reply by navicaph Feb 17 2009 @ 5:11 PM
is that cpu soldered on?
iFixit Staff
Flag Reply by Luke Soules Feb 17 2009 @ 5:27 PM
Quote from navicaph:
Yes, unfortunately the CPU is soldered to the logic board. Apple hasn't offered a laptop with the CPU on a separate board since the G3 Pismo in 2000.
Add NoteNotes: Step 21
Flag Reply by jamesb Feb 17 2009 @ 5:48 PM
What are the dimensions of the logic boards on the 17" and 15"?
iFixit Staff
Flag Reply by Luke Soules Feb 17 2009 @ 5:58 PM
Quote from jamesb:
The 17" Unibody board is about 5.5" by 9.5" (14 cm by 24 cm). The 15" Unibody board is the same height, but only about 8.25" wide (21 cm).
Flag Reply by zeolite Feb 18 2009 @ 2:40 AM
Do you guys have apple tv repairs done yet? They all have the same glitch lately that they keep restarting over and over again and my apple provider here in Iceland is saying it's not apple's fault.
I need to buy a new one they say!
Thank you so much for this web page and very professional work. I enjoy coming here every day reading!
Flag Reply by Zaico May 16 2009 @ 7:30 AM
Looks like the 17" has ekstra space for more video RAM, 4 more spaces on the same side as the CPU and GPU's are... So is it possible to "installe" 512MB ekstra video RAM?
Add NoteNotes: Step 23
Flag Reply by mm1121890 Feb 17 2009 @ 6:41 PM
Which brand and model of LCD panel is used in the unibody 17" MacBook Pro?
Flag Reply by bobcat Feb 17 2009 @ 11:31 PM
Quote from mm1121890:
and how is the full screen black overlay and mask attached to the dislay? Optical bonding?
Flag Reply by UltraNEO Feb 18 2009 @ 1:15 AM
Hiya, Is it physically impossible to dismantle the display section? As yet, I've not seen any images posted by anyone, not even yourselves.
iFixit Staff
Flag Reply by Ben Eisenman Feb 18 2009 @ 10:27 AM
Quote from UltraNEO:
The glass front panel is glued firmly to the rear panel. We haven't tried to liberate it. It is possible that heat might loosen the adhesive, but it's just as possible that the heat will smoke or break the glass. As far as I know, there isn't a feasible way to get in there.
Flag Reply by Factor Feb 18 2009 @ 1:48 PM
Quote from ben:
What if dust particles get between the glass and the LCD panel? Would there be no way to clean that out? This part concerns me.
Thanks
Flag Reply by jamesb Feb 18 2009 @ 5:55 PM
What type of connector is used on the display assembly to connect to the logic board.
Flag Reply by sacredgeometry Feb 18 2009 @ 7:30 PM
Quote from Factor:
Thanks
As far as i can tell from the descriptions of the manufacturing i have come across, the panels are sealed so dust shouldn't be an issue.
Can anyone confirm this?
iFixit Staff
Flag Reply by Kyle Wiens Feb 18 2009 @ 11:15 PM
We don't know yet. If we disassemble the display further we'll let everyone know.
Flag Reply by MacManNZ Feb 20 2009 @ 2:29 PM
Can you please disassemble the LCD so we can see the LED backlight?
thanks that would be much appreciated
keep up the great work!!!
iFixit Staff
Flag Reply by Brady Cabe Feb 20 2009 @ 4:17 PM
Quote from MacManNZ:
citing Ben above:
Flag Reply by AlanMoore Mar 18 2009 @ 7:52 AM
Does anyone know how to take the display assembly further apart? I want to add a Wacom tablet pad behind? How bad an idea is that now with the glass-enclosed displays of the Unibodies?
Flag Reply by GeeC Nov 30 2009 @ 5:58 PM
Will the display assembly work if it's not put back on the hinges, separate from the body frame? If it will work can the signal cables be extended? I'd like to make a custom display stand and use a wireless keyboard and mouse and 'hide' the computer body.
Add NoteNotes: Step 24
Flag Reply by wuntorsi Feb 18 2009 @ 6:44 AM
This is clockwise, not counterclockwise :)
iFixit Staff
Flag Reply by David Patierno Feb 18 2009 @ 9:48 AM
Quote from wuntorsi:
Thanks ^_^
Flag Reply by Ehsan Oct 15 2009 @ 7:06 AM
Love you guys at iFixit !
One thing :
why it's so hard to find Apple Service Manuals ?
( i really appreciate that you do Teardown but Service Manuals are in a lot more details !).
Iran
