Edit
Step 26
Removing the Airport card.
Disconnect the antenna connector and the data cable.
Remove the two screws.
The Bluetooth cable disappears into the display, and our sources tell us that it's sandwiched between the glass and the metal case. This means that if your Bluetooth goes out, you may have to replace the entire display!
Edit
Step 28
The "unibody" upper case assembly.
This case assembly includes the keyboard, glass trackpad, and ribbon cables.
While the manufacturing of the case is sexy, our sources say that Apple is treating this as a single replaceable part. This means that if you break a key on the keyboard, you'll have to replace the entire upper case. That could get very expensive.
Page 4 of 5
