MacBook Pro 15" Unibody Mid 2010 Teardown
Teardown
Teardown
Teardowns provide a look inside a device and should not be used as disassembly instructions.
Featured Guide
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
  • Add Note x
Stay tuned for an exciting look into one of Apple's latest revision of its MacBook Pro line, the Intel Core i5 MacBook Pro.
We gutted the Core i5 on April 14, 2010.
first image
Add Note Edit Step 1 — MacBook Pro 15" Unibody Mid 2010 Teardown  ¶
  • Apple's need for faster and better processors has led it to incorporate Core i5s and i7s into its latest lineup of MacBook Pros.
  • Our new MacBook Pro's specifications:
    • 2.4 GHz Intel Core i5 with 3 MB shared level 3 cache
    • 4 GB of 1066 MHz DD3 SDRAM
    • 15.4 inch LED-backlit glossy widescreen display
    • Intel HD Graphics and NVIDIA GeForce GT 330M with 256 MB of GDD3 RAM
first image
Add Note Edit Step 2  ¶
  • Apple is still using the model number A1286 for the new MacBook Pro. We'll have to find a new way to differentiate this laptop from previous models.
  • Perhaps Model A1286 Core i5? Only time will tell.
first image
Add Note Edit Step 3  ¶
  • Removing the rear cover will get things going.
  • Servicing the battery is not super easy due to the fact that you need a Tri-Wing screwdriver to get it out of the machine.
first image
Add Note Edit Step 4  ¶
  • Taking off the rear cover reveals a machine that is not very exciting or different from earlier MacBook Pro models.
  • As usual, there's a sticker warning against removing the battery. Por quĂ©, Apple?
first image
Add Note Edit Step 5  ¶
  • Silly sticker... You can't stop us!
  • For some odd reason, Apple has stopped using five-point Torx screws found on other MBP 15" Unibodies in favor of Tri-Wing screws. Try as you may, Apple, you won't win. We got all the screwdrivers right here.
  • The battery is now rated at 77.5 Wh. That's just a tad bit more than the 73 Wh battery found in last year's 15" model, but not enough to explain the 1-2 hour battery life improvement Apple is claiming for this machine.
  • Perhaps they optimized the Pro's power consumption?
first image
Add Note Edit Step 6  ¶
  • The Wi-Fi/Bluetooth board location is one of the few major changes made to the new model.
  • Its layout closely resembles that of the MacBook Unibody.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 7  ¶
  • Removing the AirPort/Bluetooth assembly first requires disconnecting the three antenna connectors with a plastic spudger.
  • A single screw is all that's left holding the assembly in place.
  • Two more screws need to be removed to separate the AirPort Express card.
first image
Add Note Edit Step 8  ¶
first image
Add Note Edit Step 9  ¶
  • The connectors as viewed, from left to right:
    • Wi-Fi/Bluetooth antenna
    • Camera cable
    • Optical drive
    • Speaker wires
    • Hard drive
  • Due to the redesign of the AirPort/Bluetooth interface, its connections are no longer integrated into the camera cable, greatly decreasing the size of the connector.
first image
thumb image 1
thumb image 2
Add Note Edit Step 10  ¶
  • With the antenna out of the way, the optical drive can be removed.
  • The new MacBook Pro uses the same Seagate hard drive from the previous model.
first image
thumb image 1
thumb image 2
Add Note Edit Step 11  ¶
  • Removing the speaker and subwoofer assembly requires removing four measly screws holding it on the upper case.
  • Apple changed the design of this speaker assembly slightly, moving from a single plastic enclosure to separate plastic enclosures for the speaker & subwoofer that are connected by the speaker leads.
first image
thumb image 1
thumb image 2
Add Note Edit Step 12  ¶
  • Since the AirPort/Bluetooth board is mounted inside the all-metal case of this machine, Apple added an antenna that is mounted on the frame for the optical drive opening. Pretty clever!
  • This antenna is not found on the MacBook Unibody, probably because the case of that machine is plastic and blocks less RF transmission & reception.
first image
thumb image 1
thumb image 2
Add Note Edit Step 13  ¶
  • After removing the two cooling fans and disconnecting many connectors, the logic board and DC-In board can be removed as one piece.
first image
Add Note Edit Step 14  ¶
  • The logic board and heat sink assembly by itself.
  • The speaker, microphone, and port layout are unchanged from previous MBP 15" Unibody machines.
first image
thumb image 1
thumb image 2
Add Note Edit Step 15  ¶
  • Huge versions of these scans can be found here and here. 56K beware!
  • Intel Core i5 processor with integrated graphics.
  • NVIDIA GeForce GT 330M. The OS switches to the NVIDIA graphics for higher demand applications.
  • Intel BD82HM55 S LGZS Platform Controller Hub. Interestingly enough, the hub is not connected to the heat sink. Apparently, enough heat is convected from the surface of the silicon to remove the small amount of heat generated by the graphics switching operations.
first image
Add Note Edit Step 16  ¶
first image
Add Note Edit Step 17  ¶
  • The heat sinks can be separated from the logic board, leaving it very cold and lonely.
first image
Add Note Edit Step 18  ¶
  • The Core i5 was no match for iFixit.
  • Here are the remains of this lovely machine...
Notes Add Note Notes are offturn on
