first image
thumb image 1
thumb image 2
Add Note Edit Step 9  ¶
  • The optical drive is attached via three Phillips screws.
  • The brackets and screw layout are identical to the older MacBook Unibody.
first image
thumb image 1
thumb image 2
Add Note Edit Step 10  ¶
  • Removing the optical drive exposes the right speaker.
  • It's held in place by adhesive. A quick pry with the spudger will loosen it.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 11  ¶
  • A connector, three Phillips screws, and bam -- the fan's out!
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 12  ¶
  • Disconnect the LVDS connector.
  • Remove 7 motherboard screws.
  • Remove 2 DC-in screws.
  • Disconnect trackpad, keyboard, and battery level indicator cables.
  • Remove LVDS cable retaining bracket.
  • And the logic board is almost out...
first image
thumb image 1
thumb image 2
Add Note Edit Step 13  ¶
  • Pop out the microphone from its cave.
  • The logic board is finally free!
first image
thumb image 1
thumb image 2
Add Note Edit Step 14  ¶
  • A couple of images of the logic board, before we strip it naked...
  • Like the MacBook Unibody, the heat sink comes out along with the logic board.
first image
thumb image 1
thumb image 2
Add Note Edit Step 15  ¶
  • Both sides of the logic board.
  • Hi-res pictures of the front and back.
  • Not for the faint of heart -- full-size images (5 MB a pop!): front and back.
first image
Add Note Edit Step 16  ¶
  • And here's the whole enchilada for you to enjoy.
Next » « Previous
Required Tools
Spudger
$2.95 · 50+ in stock
T6 Torx Screwdriver
$4.95 · 50+ in stock
Phillips #00 Screwdriver
Tri-wing Y1 Screwdriver
$9.95 · 50+ in stock
Recommended Tools
Home Tech Toolkit
$24.95 · 50+ in stock
Sorting Tray
$7.95 · 47 in stock
Anti-Static Wrist Strap
$7.95 · 22 in stock
Pro Tech Base Toolkit
$59.95 · 50+ in stock
Thirsty Bag
$6.95 · 50+ in stock
Popular Device Products
Notes Add Note Notes are offturn on
