first image
thumb image 1
thumb image 2
Add Note Edit Step 9  ¶
  • Getting to the optical drive takes a bit more work...
  • The rear vent is held in place by both Phillips #00 and T8 Torx screws.
  • The cast aluminum vent plate is painted with a satin white rubberized paint and probably adds a good amount of rigidity to the device.
  • The lack of structural supports like these in previous plastic MacBooks accounts for their flexibility.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 10  ¶
  • The digging continues as we remove the speaker/AirPort/Bluetooth card assembly.
  • After popping off a few connectors, removing a few screws (including one inserted into the side of the optical drive), the optical drive is almost free.
first image
Add Note Edit Step 11  ¶
  • Unlike the earlier plastic MacBooks, AirPort and Bluetooth share the same board.
  • The Bluetooth model number is BCM943224PCIEBT.
  • All three antenna cables appear to route into the display assembly. This may be an improvement for Bluetooth range, since on previous MacBooks the Bluetooth antenna was located above the optical drive and not inside the display assembly.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 12  ¶
  • After removing the final few screws, lift the optical drive out of its comfy plastic unibody home.
  • No surprises here. The optical drive is an 8x SATA SuperDrive. It's a Panasonic model UJ898, made in China September of 2009.
first image
thumb image 1
thumb image 2
Add Note Edit Step 13  ¶
  • It has a fan.
  • After a few twists of a screwdriver and the flick of a spudger, the fan lifts right out.
  • The fan design appears relatively unchanged from previous plastic MacBooks, except that it mounts to the upper case on this model.
first image
thumb image 1
thumb image 2
Add Note Edit Step 14  ¶
  • Six T6 screws and several fragile connectors stand between us and logic board freedom.
first image
thumb image 1
thumb image 2
Add Note Edit Step 15  ¶
  • The logic board removed.
  • Like the MacBook Pro Unibody, Apple nicely designed this machine so the logic board and heat sink come out as a single part. This way, you'll only need to get your hands dirty with thermal paste if you're replacing the logic board.
first image
thumb image 1
thumb image 2
Add Note Edit Step 16  ¶
  • The MacBook sports a NVidia 9400M GPU and an Intel Core 2 Duo 2.26 GHz CPU.
  • This is exactly the same GPU and CPU in the base model 13" Unibody MacBook Pro. This CPU offers a whopping 130 MHz increase over the 2.13 GHz chip that powered the old plastic MacBook.
Next » « Previous
Required Tools
T8 Torx Security Bit Screwdriver
$6.95 · 47 in stock
Spudger
$2.95 · 50+ in stock
T6 Torx Screwdriver
$4.95 · 50+ in stock
Phillips #00 Screwdriver
Tri-wing Y1 Screwdriver
$9.95 · 27 in stock
Recommended Tools
Home Tech Toolkit
$24.95 · 50+ in stock
Sorting Tray
$7.95 · 50+ in stock
Anti-Static Wrist Strap
Pro Tech Base Toolkit
$59.95 · 50+ in stock
Thirsty Bag
$6.95 · 50+ in stock
Popular Device Products
Notes Add Note Notes are offturn on
