MacBook Air Teardown
Add Note Introduction
Author: Luke Soules
We disassembled this laptop on February 1, 2008.
View as slideshow
Teardown Warning
Teardown
Teardowns provide a look inside a device and should not be used as disassembly instructions.
Paginated Single Page Steps
first image
Add Note Step 1 — MacBook Air Teardown
  • We were relieved to discover the MacBook Air ships in more than just a manila envelope.
first image
Add Note Step 2
  • The MacBook Air adds yet another power adapter to Apple's impressively-varied lineup, and is the first Mactel to run on 45 watts.
  • A comparison, from top to bottom:
    • iPhone (5-watt)
    • iPod (8-watt)
    • MacBook Air (45-watt)
    • MacBook (60-watt)
    • MacBook Pro (85-watt)
first image
Add Note Step 3
  • The new MagSafe power adapter has been rotated 90 degrees to handle the Air's extreme thinness.
  • The earlier MacBook power adapter works, but won't fit when the Air is placed on a flat surface.
first image
Add Note Step 4
  • The more traditional ports are hidden in a bay that drops down to reveal:
    • One USB port.
    • One headphone jack.
    • And one micro-DVI port.
  • The placement of the ports means that the Air doesn't play nicely with bulky connectors. To get your Air to sit flat on the desktop, you'll need either a dongle or slim connectors.
first image
Add Note Step 5
  • Laptop on laptop action.
  • The Air makes the MacBook look like the new iBook.
first image
Add Note Step 6
  • As you'd expect with a computer so devoted to aesthetics, getting to the "user-installable" parts is going to be a bit more challenging than usual.
  • The bottom case is held down by 10 screws:
    • Six 3mm #00 Phillips.
    • Two 5.4mm #00 Phillips.
    • Two 7.9mm #00 Phillips.
first image
Add Note Step 7
  • Removing the lower case proved a surprisingly pleasant task. Thanks Apple.
first image
Add Note Step 8
  • Look! We found the battery.
  • Unfortunately, it's no longer considered a user-installable part by Apple and is attached to the case by 9 screws:
    • Four 3mm #00 Phillips.
    • Four 3.8mm #00 Phillips.
    • One 7.3mm #00 Phillips.
Notes
There are no notes
