MacBook Air Models A1237 and A1304 Teardown
Teardown
Teardown
Teardowns provide a look inside a device and should not be used as disassembly instructions.
  • Add Note x
We disassembled this laptop on February 1, 2008.
first image
Add Note Edit Step 1 — MacBook Air Models A1237 and A1304 Teardown  ¶
  • We were relieved to discover the MacBook Air ships in more than just a manila envelope.
first image
Add Note Edit Step 2  ¶
  • The MacBook Air adds yet another power adapter to Apple's impressively-varied lineup, and is the first Mactel to run on 45 watts.
  • A comparison, from top to bottom:
    • iPhone (5-watt)
    • iPod (8-watt)
    • MacBook Air (45-watt)
    • MacBook (60-watt)
    • MacBook Pro (85-watt)
first image
Add Note Edit Step 3  ¶
  • The new MagSafe power adapter has been rotated 90 degrees to handle the Air's extreme thinness.
  • The earlier MacBook power adapter works, but won't fit when the Air is placed on a flat surface.
first image
Add Note Edit Step 4  ¶
  • The more traditional ports are hidden in a bay that drops down to reveal:
    • One USB port.
    • One headphone jack.
    • And one micro-DVI port.
  • The placement of the ports means that the Air doesn't play nicely with bulky connectors. To get your Air to sit flat on the desktop, you'll need either a dongle or slim connectors.
first image
Add Note Edit Step 5  ¶
  • Laptop on laptop action.
  • The Air makes the MacBook look like the new iBook.
first image
Add Note Edit Step 6  ¶
  • As you'd expect with a computer so devoted to aesthetics, getting to the "user-installable" parts is going to be a bit more challenging than usual.
  • The bottom case is held down by 10 screws:
    • Six 3mm #00 Phillips.
    • Two 5.4mm #00 Phillips.
    • Two 7.9mm #00 Phillips.
first image
Add Note Edit Step 7  ¶
  • Removing the lower case proved a surprisingly pleasant task. Thanks Apple.
first image
Add Note Edit Step 8  ¶
  • Look! We found the battery.
  • Unfortunately, it's no longer considered a user-installable part by Apple and is attached to the case by 9 screws:
    • Four 3mm #00 Phillips.
    • Four 3.8mm #00 Phillips.
    • One 7.3mm #00 Phillips.
Next » « Previous
Popular Device Products
MacBook Air 45W Apple AC Adapter
$59.95 · 35 in stock
Arctic Silver Thermal Paste
$8.95 · 50+ in stock
Arctic Silver ArctiClean
$7.95 · 50+ in stock
Notes Add Note Notes are offturn on
