Mac mini Model A1283 Teardown
Teardown
Teardown
Teardowns provide a look inside a device and should not be used as disassembly instructions.
  • Add Note x
We picked up the new Mac mini from our local Apple store and took it apart!
first image
thumb image 1
thumb image 2
Add Note Edit Step 1 — Mac mini Model A1283 Teardown  ¶
  • The Mac mini for this First Look was graciously provided by our friends at macminicolo, a Mac mini colocation service. They allow your Mac mini to be used as a surprisingly powerful and inexpensive server.
  • Ladies and gentlemen, without further ado, allow us to introduce the new and improved Mac mini!
  • We immediately tried to open the mini using our iMac opening tool, used in yesterday's iMac First Look.
    • It did not work.
  • We also posted a guide for installing a second hard drive in the Mac Mini.
first image
thumb image 1
thumb image 2
Add Note Edit Step 2  ¶
  • The beauty of evolution at its finest. From left to right: Power PC, Intel Core Duo, Intel Core 2 Duo.
  • Notable differences in the latest model:
    • An additional USB port brings the total to five, one more than the previous model (and three more than the Power PC!).
    • A Mini DisplayPort and mini-DVI port -- which allow for Dual-Monitor support for the first time in a Mac mini -- replace the DVI display port of the previous generation.
    • A Firewire 800 port replaced the old FireWire 400 port, much to the chagrin of Mac users.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 3  ¶
  • Let's rock this thing!
  • Carefully insert a putty knife into the crevice in between the top cover and bottom housing. Start on the left side first.
  • Gently enlarge the existing crevice by twisting the putty knife downward and away from the mini.
  • Repeat the prying motion until a portion of the bottom housing has been nudged upward.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 4  ¶
  • Repeat the same prying procedure on the right side.
  • The top cover should now be marginally separated from the bottom housing. Use your fingers to completely separate the two, starting with the I/O side of the mini.
  • The top cover does not have any cables attaching it to the bottom housing; it should now be completely detached from the bottom.
first image
Add Note Edit Step 5  ¶
  • A quick comparison photo of the three Mac mini generations (oldest on left) showcases their technological progression:
    • No antennas --> One antenna --> Two antennas (Airport card)
    • Desktop RAM --> laptop RAM
    • PATA --> SATA drives
first image
Add Note Edit Step 6  ¶
  • Can you hear me now? Excellent.
  • The wireless board contains a Broadcom BCM4312KFBGH WiFi transceiver on it.
  • The new mini houses three wireless communications antennas, one for use with the built-in Bluetooth and two for the Airport Extreme wireless 802.11n card.
  • All three antennas need to be removed before accessing the hardware underneath.
first image
thumb image 1
thumb image 2
Add Note Edit Step 7  ¶
  • There are two black posts securing the Airport antenna board to the internal frame.
  • Squeeze both black posts together and gently lift the antenna board from the post.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 8  ¶
  • Rotate the mini 180 degrees.
  • Use a spudger to peel back the black tape and release the antenna cable.
  • Carefully lift the remaining two antennas from the right side of the mini.
Next » « Previous
Required Tools
Phillips #0 Screwdriver
$4.95 · 50+ in stock
1.5" Thin Putty Knife
Recommended Tools
Home Tech Toolkit
$24.95 · 50+ in stock
Sorting Tray
$7.95 · 47 in stock
Anti-Static Wrist Strap
$7.95 · 22 in stock
Pro Tech Base Toolkit
$59.95 · 50+ in stock
Thirsty Bag
$6.95 · 50+ in stock
Popular Device Products
PC3-8500 2 GB RAM Chip
$49.95 · 29 in stock
Arctic Silver Thermal Paste
$8.95 · 50+ in stock
Arctic Silver ArctiClean
$7.95 · 50+ in stock
Notes Add Note Notes are offturn on
