Mac Mini Model A1347 Teardown
Teardown
Teardown
Teardowns provide a look inside a device and should not be used as disassembly instructions.
Featured Guide
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
  • Add Note x
Join us as we take a peek inside at Apple's newest revision of the Mac Mini, now with an HDMI port!
Check out the YouTube video slideshow of the teardown as well!
first image
thumb image 1
thumb image 2
Add Note Edit Step 1 — Mac Mini Model A1347 Teardown  ¶
  • Well folks, after much clamor, it seems the engineers at Apple have finally included an HDMI port in an actual Apple product.
  • Notable Tech Specs:
    • 2.4 or 2.66 GHz Intel Core 2 Duo processor
    • 2 GB of RAM (expandable up to 8 GB)
    • NVIDIA GeForce 320M graphics processor with 256MB of shared DDR3 SDRAM (the same as the most recent MacBook)
    • HDMI port with support for up to 1920-by-1200 resolution
    • AirPort Extreme 802.11n Wi-Fi wireless networking
    • SD card slot
first image
Add Note Edit Step 2  ¶
  • Contents of box:
    • Mac Mini
    • HDMI to DVI adapter
    • Power cord
first image
thumb image 1
thumb image 2
Add Note Edit Step 3  ¶
  • Departing from previous generations, the Mini's unibody top enclosure is machined from a single block of aluminum.
  • Measuring 1.4 x 7.7 x 7.7 inches and weighing only 3 lbs, this is truly one for the books.
  • The black logo and other accents match quite nicely with the styling of Apple's iPad and recent iMacs. Congrats, Mini, you're no longer the black sheep of the family!
  • The model number for this new unit is A1347.
first image
Add Note Edit Step 4  ¶
  • The Mini's new port layout is indeed surprising:
    • AC power in
    • Built-in 10/100/1000BASE-T ethernet
    • Firewire 800
    • HDMI
    • Mini DisplayPort
    • Four USB 2.0 ports, down one from the previous Mac Mini
    • SD card slot
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 5  ¶
  • In comparison to the Mac Mini model A1176, the Mid 2010 is thinner and wider.
  • There is a definite difference in height between the Mid 2010 and previous iterations.
first image
thumb image 1
thumb image 2
Add Note Edit Step 6  ¶
  • With a simple counter-clockwise twist, the black access plate can be removed for easy RAM and fan access.
  • Gone are the days of the putty knife...you will be missed old friend...
first image
Add Note Edit Step 7  ¶
  • Much like many other new Apple products, removing the RAM is quite feasible this time around.
  • This little guy comes with two SO-DIMM slots capable of supporting up to 8GB of RAM.
  • Our base unit came strapped with two gigs of RAM.
first image
thumb image 1
thumb image 2
Add Note Edit Step 8  ¶
  • After removing two screws, the fan can be lifted out to access its power connector.
  • The connectors inside this machine look pretty consistent with those found in Apple's current product lineup. Nothing too new here.
  • All three fan screws are isolated with rubber dampers; a feature not seen on older apple machines. Low noise and vibration are big selling points for Apple these days, and the new Mini's idle emission of 14 dB is a testament to those design goals.
Next » « Previous
Popular Device Products
Universal Drive Adapter
$29.95 · 42 in stock
Arctic Silver Thermal Paste
$8.95 · 50+ in stock
Arctic Silver ArctiClean
$7.95 · 50+ in stock
Notes Add Note Notes are offturn on
