Image #1 Image #2
Add Note Edit Step 9  ¶
  • The heat sink is next to go.
  • Apple has really keyed in on their boomerang-style heat sink abilities—and for that, we applaud them. We know boomerangs can be tough to master.
  • Similar, again! We have not tried installing old 2011 Mini parts in the 2012 Mini, but we are certainly not ruling out the possibility!
Image #1 Image #2 Image #3
Add Note Edit Step 10  ¶
  • A series of screws and tightly wrapped antenna cables secure the rear I/O panel shield to the logic board.
  • A few twists of our precision aluminum driver with a T6 Torx bit and some cable de-routing is all it takes to remove the shield.
Image #1
Add Note Edit Step 11  ¶
  • Some mini players on the top of the not-so-mini logic board:
    • Cirrus Logic 4206B Audio Controller
    • SMSC USB2512B USB Hub Controller
    • Broadcom BCM57765 gigabit ethernet and memory card controller
    • Intel L232TB45 Thunderbolt Port Controller
    • LSI L-FW643E-2
    • AELTA 8904C-F
Image #1
Add Note Edit Step 12  ¶
  • The rear side of the logic board:
    • Intel E224B809 platform controller hub
    • Intel V227C254 2.5 GHz dual-core i5
    • SMSC 1428-7 system management bus temperature sensor
    • Parade PS8401A HDMI/DVI level shifter
    • AELTA 8904C-F
    • LM4FS1AH
Image #1 Image #2
Add Note Edit Step 13  ¶
  • Tucked away neatly near the rear of the Mini is the hard drive.
  • Our model came with a 500 GB Hitatchi hard drive.
  • The Mini is one of the Macs launched with the Fusion Drive.
Add Note Edit Step 14  ¶
  • Next up, we displace the power of the Mini.
  • It is beginning to feel repetitive to say how repetitive Apple is in the design of the Mini; nonetheless, the power supply appears identical to last year's model.
    • In this case, we have to say that repetition is a good thing, as the Mini continues to be one of the most repairable devices that Apple produces.
  • Just like last year, the power supply provides 85 watts to the Mac Mini—that's the same kind of electric juice as the AC adapter for a 15" or 17" MacBook Pro.
Add Note Edit Step 15  ¶
  • We were especially curious to see if this new Mac Mini is still compatible with our dual hard drive upgrade kit, so we got to testing it!
  • Following along with our own guide for the 2011 model was a snap, and everything fit perfectly.
  • After a quick reassembly, we booted this guy up for the first time—with 50% extra storage. Success!
Image #1 Image #2
Add Note Edit Step 16  ¶
  • Mac Mini Mid 2012 Repairability: 8 out of 10 (10 is easiest to repair).
    • No proprietary screws are found within the device.
    • You can easily upgrade your RAM and hard drive, as well as add a secondary drive.
    • There's no glue anywhere inside that needs to be removed while disassembling the Mini.
    • The CPU is soldered to the logic board and not user-upgradeable.
    • While not difficult to do, you still have to remove almost all the internals in order to replace the power supply.
Next » « Previous
Required Tools
T8 Torx Security Bit Screwdriver
$6.95 · 50+ In stock
Spudger
$2.95 · 50+ In stock
T6 Torx Screwdriver
$4.95 · 50+ In stock
Phillips #00 Screwdriver
Mac Mini Logic Board Removal Tool
$4.95 · 34 In stock
Related Products
Mac Mini Dual Drive Kit
$49.95 · 50+ In stock
Recommended Tools
Universal Drive Adaptor
$29.95 · 50+ In stock
iFixit Lock Pick Set
$29.95 · 19 In stock
Inspection Scope
$39.95 · 38 In stock
Frictionless Ratchet
$24.95 · 48 In stock
Portable Anti-Static Mat
$24.95 · 16 In stock
