Logitech Quickcam 9000 Pro Teardown
Teardown
Teardown
Teardowns provide a look inside a device and should not be used as disassembly instructions.
User-Contributed Guide
This guide is not managed by iFixit staff.
  • Add Note x
This is a step by step teardown of a Logitech webcam which is helpful if you are trying to build a stereo camera or adjust the focus.
Focus adjustments require making a lens adjustment tool.
first image
thumb image 1
thumb image 2
Add Note Edit Step 1 — Logitech Quickcam 9000 Pro Teardown  ¶
first image
thumb image 1
thumb image 2
Add Note Edit Step 2  ¶
  • Remove screws where shown by the green arrows.
first image
thumb image 1
thumb image 2
Add Note Edit Step 3  ¶
  • Remove e-ring to detach grommet.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 4  ¶
  • Remove screws indicated by the green arrows.
  • Do not remove the screws indicated by the red arrows at this point.
  • Autofocus system contains magnets.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 5  ¶
  • Remove cover.
first image
Add Note Edit Step 6  ¶
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 7  ¶
  • The screws indicated in red can now be removed. The screws are glued into place and removal can be assisted by heating gently with a soldering iron.
  • Autofocus motor connections can be removed by desoldering using desoldering braid where indicated.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 8  ¶
  • Almost done.
Next » « Previous
Required Tools
Phillips #0 Screwdriver
$4.95 · 50+ in stock
Phillips #00 Screwdriver
Soldering Station
$24.95 · 35 in stock
Desoldering Braid
Recommended Tools
Home Tech Toolkit
$24.95 · 50+ in stock
Sorting Tray
$7.95 · 50+ in stock
Anti-Static Wrist Strap
Pro Tech Base Toolkit
$59.95 · 50+ in stock
Thirsty Bag
$6.95 · 50+ in stock
Popular Products
T10 Torx Screwdriver
Small Suction Cup
$2.95 · 50+ in stock
54 Bit Driver Kit
26 Bit Driver Kit
$14.95 · 50+ in stock
Precision Tweezers Set
$7.95 · 28 in stock
Notes Add Note Notes are offturn on
