Logitech 2-MP Webcam C600 Teardown
Teardown
Teardown
Teardowns provide a look inside a device and should not be used as disassembly instructions.
User-Contributed Guide
This guide is not managed by iFixit staff.
  • Add Note x
This is a step by step teardown of a Logitech webcam which is helpful if you are trying to build a stereo camera and remove the infrared filter or even simply adjust the focus.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 1 — Logitech 2-MP Webcam C600 Teardown  ¶
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 2  ¶
  • Pry off the button mounted on the side
  • Green arrow indicates the location of screw hole
  • Use a #0 Phillips head screwdriver to remove the screw
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 3  ¶
  • Remove the screw indicated by the green arrows
  • The lens can be screwed and unscrewed to adjust focus. However it is glued in place and should be reglued after adjustment
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 4  ¶
  • The screws indicated by the blue arrows hold the lens module in place
  • The infrared filter is accessible from the back of the lens module. It is the shiny piece of reddish glass.
first image
thumb image 1
thumb image 2
Add Note Edit Step 5  ¶
  • Attached to the white plastic is the privacy shade position sensor.
  • The ccd sensor appears to be 1/3.2" Type sensor with 4:3 aspect ratio. With is 4.536mm x 3.416mm. Focal length is currently undetermined.
  • The lens is threaded M10x0.5, and testing seems to indicate that the sensor is a CCD with global shutter.
Notes Add Note Notes are offturn on
