This teardown is not a repair guide. To repair your Linksys BEFW11S4, use our service manual.
  1. Linksys BEFW11S4 Teardown, Linksys BEFW11S4 Teardown: step 1, image 1 of 1
    • Waiting to be disassembled...
  2. Linksys BEFW11S4 Teardown: step 2, image 1 of 3 Linksys BEFW11S4 Teardown: step 2, image 2 of 3 Linksys BEFW11S4 Teardown: step 2, image 3 of 3
    • Remove antennas.
    • Remove nuts and washers around antenna connectors.
    • Push in antenna connectors.
  3. Linksys BEFW11S4 Teardown: step 3, image 1 of 3 Linksys BEFW11S4 Teardown: step 3, image 2 of 3 Linksys BEFW11S4 Teardown: step 3, image 3 of 3
    • Remove feet (with flat-head screwdriver, fingernails, etc).
    • Unscrew the screws.
  4. Linksys BEFW11S4 Teardown: step 4, image 1 of 2 Linksys BEFW11S4 Teardown: step 4, image 2 of 2
    • Pull apart blue front from black back with a LOT of force.
    • Slide and pull up bottom. (Make sure the antenna connectors get through.)
  5. Linksys BEFW11S4 Teardown: step 5, image 1 of 1
    • Twist and pull out antenna connector feeds.
  6. Linksys BEFW11S4 Teardown: step 6, image 1 of 3 Linksys BEFW11S4 Teardown: step 6, image 2 of 3 Linksys BEFW11S4 Teardown: step 6, image 3 of 3
    • Pull up RF shield from motherboard.
    • Unscrew the motherboard from the bottom.
    • Push the motherboard forward (as in this picture) to unlatch it from the bottom.
  7. Linksys BEFW11S4 Teardown: step 7, image 1 of 2 Linksys BEFW11S4 Teardown: step 7, image 2 of 2
    • Some people have a card where you have to unscrew it. If that is your case, do that. The instructions below is for my type of router.
    • Push the card forward to deattach the pins.
    • Remove the card from the metal holdster.
  8. Linksys BEFW11S4 Teardown: step 8, image 1 of 1
    • Here are the markings on the motherboard chips. If you have any info on these chips, please comment!
    • Macronix 29F040QC-90
    • ISSI IS41C16100S-50K
    • SAMSUNG ARM S3C4510X01-QERO
    • RMC RTL8019AS
    • Bothhands FB2022
    • Bothhands 40ST1041E
    • Kendin KS8995. Kendin has since been bought by Micrel.
  9. Linksys BEFW11S4 Teardown: step 9, image 1 of 1
    • Enjoy!
William McKinnerney
65 Reputation
1 Guide authored
2 Comments
what is that card inside this router
hartiTube - Reply
Thank you. I accomplished this task. Except my antenna wires were soldered to the board.
Darren - Reply
Past 24 Hours: 2
Past 7 Days: 18
Past 30 Days: 25
All Time: 9,054
