LG Rumor LX260 Teardown
Teardown
Teardown
Teardowns provide a look inside a device and should not be used as disassembly instructions.
User-Contributed Guide
This guide is not managed by iFixit staff.
  • Add Note x
The LG Rumor is a full QWERTY keyboard slider phone available from Sprint in 2008. It has an SD card slot and runs a unique OS.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 1 — LG Rumor LX260 Teardown  ¶
first image
thumb image 1
thumb image 2
Add Note Edit Step 2  ¶
  • Now, start by removing the battery, it is attatched to the back cover, and can be removed by pushing the tab back.
first image
thumb image 1
thumb image 2
Add Note Edit Step 3  ¶
  • Remove these 6 phillips screws:
  • These two top screws are covered by rubber plugs that can be removed by a small flathead screwdrivew, or a fingernail.
first image
thumb image 1
thumb image 2
Add Note Edit Step 4  ¶
  • Remove the covers for the Headphone, Micro SD and Charging connectors, but be careful, they are still connected, pull them only as far as they will come out!
first image
Add Note Edit Step 5  ¶
  • You should now be able to lift the back cover off, it is held on with a mild adhesive, so a little force may be required the first time.
first image
thumb image 1
thumb image 2
Add Note Edit Step 6  ¶
  • Remove the "Camera" and "Volume" buttons.
  • Be careful, the actual buttons, ane attatched to the locic board with a very thin ribbon cable, only remove the button covers.
first image
thumb image 1
thumb image 2
Add Note Edit Step 7  ¶
  • Remove these two phillips screws:
  • Now, removed the highlighted clips (2nd Picture) this will free the logic board.
  • I recomend starting with this one, and once this tab is free, you can just slide it around the other clips.
first image
thumb image 1
thumb image 2
Add Note Edit Step 8  ¶
  • Now, pivot the logic board up, to reveal the LCD/Numeric Keypad Cable, remove this with a spudger or flathead screwdriver.
  • You should now be able to remove the logic board.
first image
Add Note Edit Step 9  ¶
  • The Logic board:
  • The CPU is a Qualcomm MSM6100 ARM Processor
  • The RAM, it is manufactured by Hynix
  • The Camera 1.3MP, not bad
  • The SD Card Slot:
  • Speaker [Speakerphone]
  • Headphone Jack:
  • Battery Contacts:
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 10  ¶
  • The keypad cover is easily replacable, and simply lifts out.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 11  ¶
  • Seperating the phone sliding assembly:
  • Remove these 4 Phillips screws:
  • Now, lift it off, threading the Screen/Number Pad Cable Through the hole.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 12  ¶
  • Remove these phillips screws:
  • To remove all 6, you will need to slide the sliding assembly to get to the center two screws.
  • Now, using a spudger, or flathead screwdriver, seperate the two halves of the assembly, threading the data cable through it's hole.
  • This may take a little force since a mild adhesive is applied around the rim.
first image
thumb image 1
thumb image 2
Add Note Edit Step 13  ¶
  • Now, detatch the data cable from the board using a spudger, be careful, it is a fragile connector, and you should lift it straight up.
  • Now, remove this piece of clear yellow-tinted tape covering the connectors.
first image
thumb image 1
thumb image 2
Add Note Edit Step 14  ¶
  • You will now need to remove this piece of gold-mesh tape.
  • BE CAREFUL WHEN REMOVING THIS, SINCE IT PROVIDES A GROUND, AND WILL NEED TO BE PUT BACK IN UPON RE-ASSEMBLY!
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 15  ¶
  • Now, flip this tab up, towards the bottom of the phone, and remove the speaker/side-button cable.
  • Now, slowly lift the cable up, minding the adhesive on the back.
  • When you come to the buttons, be especially careful, and when you get to the speaker, use a flathead screwdriver, and pop the speaker out.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 16  ¶
  • Using a spudger or flathead screwdriver, lift this tab up, to release the display cable.
  • Now, guide the cable out of the connector, until you can set it on top of the assembly.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 17  ¶
  • Now, to remove the board, use a flathead screwdriver or spudger to clear the tab on one side, then remove the board completly, similarly to the logic board.
first image
thumb image 1
thumb image 2
Add Note Edit Step 18  ¶
  • You can now lift the keypad cover off, just like we did earlier with the alphabetical keyboard.
first image
thumb image 1
thumb image 2
Add Note Edit Step 19  ¶
  • Unfortionatly, the LCD panel is held in place by a heavy adhesive, and removal will almost certianly crack the screen, so only remove it if you are replacing the screen.
first image
Add Note Edit Step 20  ¶
  • Group Shot!
