LG Rumor LX260 Teardown
Teardown
Teardown
Teardowns provide a look inside a device and should not be used as disassembly instructions.
User-Contributed Guide
This guide is not managed by iFixit staff.
  • Add Note x
The LG Rumor is a full QWERTY keyboard slider phone available from Sprint in 2008. It has an SD card slot and runs a unique OS.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 1 — LG Rumor LX260 Teardown  ¶
first image
thumb image 1
thumb image 2
Add Note Edit Step 2  ¶
  • Now, start by removing the battery, it is attatched to the back cover, and can be removed by pushing the tab back.
first image
thumb image 1
thumb image 2
Add Note Edit Step 3  ¶
  • Remove these 6 phillips screws:
  • These two top screws are covered by rubber plugs that can be removed by a small flathead screwdrivew, or a fingernail.
first image
thumb image 1
thumb image 2
Add Note Edit Step 4  ¶
  • Remove the covers for the Headphone, Micro SD and Charging connectors, but be careful, they are still connected, pull them only as far as they will come out!
first image
Add Note Edit Step 5  ¶
  • You should now be able to lift the back cover off, it is held on with a mild adhesive, so a little force may be required the first time.
first image
thumb image 1
thumb image 2
Add Note Edit Step 6  ¶
  • Remove the "Camera" and "Volume" buttons.
  • Be careful, the actual buttons, ane attatched to the locic board with a very thin ribbon cable, only remove the button covers.
first image
thumb image 1
thumb image 2
Add Note Edit Step 7  ¶
  • Remove these two phillips screws:
  • Now, removed the highlighted clips (2nd Picture) this will free the logic board.
  • I recomend starting with this one, and once this tab is free, you can just slide it around the other clips.
first image
thumb image 1
thumb image 2
Add Note Edit Step 8  ¶
  • Now, pivot the logic board up, to reveal the LCD/Numeric Keypad Cable, remove this with a spudger or flathead screwdriver.
  • You should now be able to remove the logic board.
Next » « Previous
Required Tools
Spudger
$2.95 · 50+ in stock
Phillips #00 Screwdriver
$4.95 · 50+ in stock
Flathead 3/32" or 2.5 mm Screwdriver
Recommended Tools
Home Tech Toolkit
$24.95 · 50+ in stock
Sorting Tray
$7.95 · 50+ in stock
Anti-Static Wrist Strap
Pro Tech Base Toolkit
$59.95 · 50+ in stock
Thirsty Bag
$6.95 · 50+ in stock
Popular Products
Metal Spudger
Metal Spudger Set
Heavy-duty Suction Cups (Pair)
$14.95 · 50+ in stock
Jeweler's Loupe LED Magnifier
$9.95 · 50+ in stock
Notes Add Note Notes are offturn on
