This teardown is not a repair guide. To repair your KORG Monotron, use our service manual.
  1. KORG Monotron Teardown, The KORG Monotron: step 1, image 1 of 3 KORG Monotron Teardown, The KORG Monotron: step 1, image 2 of 3 KORG Monotron Teardown, The KORG Monotron: step 1, image 3 of 3
  2. KORG Monotron Teardown, Opening: step 2, image 1 of 3 KORG Monotron Teardown, Opening: step 2, image 2 of 3 KORG Monotron Teardown, Opening: step 2, image 3 of 3
    • Only 4 PH1 screws
    • Note: Made in Japan !
    • Take care at the cables between two sides
  3. KORG Monotron Teardown, Remove the connectors: step 3, image 1 of 3 KORG Monotron Teardown, Remove the connectors: step 3, image 2 of 3 KORG Monotron Teardown, Remove the connectors: step 3, image 3 of 3
    • Remove '''the flat cable''' from the ribbon controller to the pcb (pull with care using hands)
    • Remove the 2 ways connector for the speaker. Use hands (with care)
    • Take max care to the speaker controller. Easy to remove but difficult to re insert
  4. KORG Monotron Teardown, Parts: step 4, image 1 of 2 KORG Monotron Teardown, Parts: step 4, image 2 of 2
    • Loudspeaker is glued to the enclosure
  5. KORG Monotron Teardown, Board: step 5, image 1 of 2 KORG Monotron Teardown, Board: step 5, image 2 of 2
    • Here a really good image of the Monotron - Courtesy of Tim Stinchcombe
  6. KORG Monotron Teardown: step 6, image 1 of 1
    • Full IC Identification:
    • You may need to enlarge it to view the text.
Carlo Romagnoli
310 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 44
All Time: 3,183
