This teardown is not a repair guide. To repair your Hyundai H-150, use our service manual.
  1. Hyundai H-150 Teardown, Hyundai H-150 Teardown: step 1, image 1 of 3 Hyundai H-150 Teardown, Hyundai H-150 Teardown: step 1, image 2 of 3 Hyundai H-150 Teardown, Hyundai H-150 Teardown: step 1, image 3 of 3
    • We'll start with a preview of the phone. Front, back and side view are shown here.
  2. Hyundai H-150 Teardown: step 2, image 1 of 3 Hyundai H-150 Teardown: step 2, image 2 of 3 Hyundai H-150 Teardown: step 2, image 3 of 3
    • The battery is removed easily. Just pull down the part from the back and the battery goes out.
  3. Hyundai H-150 Teardown: step 3, image 1 of 3 Hyundai H-150 Teardown: step 3, image 2 of 3 Hyundai H-150 Teardown: step 3, image 3 of 3
    • After the battery is out, we're presented with a plastic cover with all the phone's information (Model No., Serial No etc)
    • Notice the 4 Philips screw-heads in each of the four corners. Those need to go off.
    • After unscrewing, you might notice that the cover doesn't easily go off. Four clips are holding the back cover onto the front cover.
    • Use a Spudger and unclip the sides of the cover. It shouldn't put up much resistance
  4. Hyundai H-150 Teardown: step 4, image 1 of 3 Hyundai H-150 Teardown: step 4, image 2 of 3 Hyundai H-150 Teardown: step 4, image 3 of 3
    • Once the back cover is off, one can see the motherboard and a strange metal part on the top of the phone. This serves as an antenna booster, but also to protect the board.
  5. Hyundai H-150 Teardown: step 5, image 1 of 3 Hyundai H-150 Teardown: step 5, image 2 of 3 Hyundai H-150 Teardown: step 5, image 3 of 3
    • See that hole in the shield? That Has a screw in it. And yes, it needs to leave.
    • After removing the screw from the shield, it can be lifted from the board easily, revealing another board beneath it.
  6. Hyundai H-150 Teardown: step 6, image 1 of 3 Hyundai H-150 Teardown: step 6, image 2 of 3 Hyundai H-150 Teardown: step 6, image 3 of 3
    • It seems that this secondary board is held onto the main board by a board connector.
    • Pull the board gently and you'll notice it comes out rather fast.
  7. Hyundai H-150 Teardown: step 7, image 1 of 3 Hyundai H-150 Teardown: step 7, image 2 of 3 Hyundai H-150 Teardown: step 7, image 3 of 3
    • By this stage, the board simply comes out of the front body, exposing the keyboard and its associated membrane.
    • On the board we encounter the ringer(upper left), the headphone/handsfree input(under the ringer) and the LCD (which is sadly sticked on the board, as is the keypad membrane)
    • On the case we encounter the microphone (lowest part of the phone case), the loudspeaker (the highest part of the phone case)
  8. Hyundai H-150 Teardown: step 8, image 1 of 2 Hyundai H-150 Teardown: step 8, image 2 of 2
    • That concludes the teardown for now.
Nicolay
371 Reputation
3 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 14
All Time: 833
