Image #1 Image #2
Add Note Edit Step 9  ¶
  • The RAM replacement requires flexing a couple of fingers.
  • We would praise the Z1 for having easy-to-remove RAM modules, but then we remembered that most computers have easy-to-remove RAM modules.
  • The Z1 is capable of supporting up to 32 GB of DDR3 RAM. If you have to ask why you need 32 GB, then you clearly don't need it.
Image #1 Image #2
Add Note Edit Step 10  ¶
  • Next out is the grab-and-go power supply — 400 watts of "that was easy."
  • We're not nearly as worried about zapping ourselves on this power supply as we are with other, more naked versions.
  • Hopefully, the ease of replacement of the power supply does not fortell an ease of failure.
Image #1 Image #2
Add Note Edit Step 11  ¶
  • What's under the big black casing? Nothing, at least in our $2,000 "cheapo" machine.
  • If you shell out a few more clams for your Z1, you'll find a fancy schmancy NVIDIA Quadro graphics card here, as seen by HP's artistic rendering in the second image.
Image #1 Image #2
Add Note Edit Step 12  ¶
  • The internal USB is a great place to hide the wireless mouse dongle.
    • We would like to take a second to reflect on how awesome this is. Imagine being able to plug in that annoying wireless dongle and never think about it again. Incredible!
Image #1
Add Note Edit Step 13  ¶
  • Finally! Our first screws. We were beginning to worry there would be no use for our 54 Bit Driver Kit.
  • But even with pesky Torx T15 screws, removing the fans and heatsink from the top of the CPU is super-simple.
Image #1 Image #2 Image #3
Add Note Edit Step 14  ¶
Add Note Edit Step 15  ¶
  • This is almost too easy! A simple flip of a lever and the Intel processor practically jumps off the motherboard.
  • These days we mostly encounter soldered-on CPUs on laptops and smartphones, so it's a bit refreshing to touch and feel a nice hunk of CPU silicon in one's hand. Even though this machine is nothing like the PC beige-boxes some of us built back in the day, there's something comforting about holding a can-be-upgraded CPU and inspecting it up close.
  • Fake rumor confirmed: our Z1 did, in fact, come with an Intel Core i3 2120 processor, running at 3.30 GHz.
Image #1
Add Note Edit Step 16  ¶
  • According to the Z1 treasure map, this little button is for resetting the CMOS. No more jumpers to short out. Cool.
  • This connector is where the power button plugs into the motherboard.
  • And, according to the same treasure map, this connector allows you to plug in a second internal USB port, should you need another one inside the device.
Next » « Previous
Required Tools
Spudger
$2.95 · 50+ In stock
T6 Torx Screwdriver
$4.95 · 13 In stock
T15 Torx Screwdriver
$6.95 · 2 In stock
Recommended Tools
Universal Drive Adapter
$29.95 · 50+ In stock
Inspection Scope
$39.95 · 17 In stock
Portable Anti-Static Mat
$24.95 · 10 In stock
Popular Products
26 Bit Driver Kit
$19.95 · 3 In stock
Pro Tech Toolkit
$69.95 · 50+ In stock
Inspection Scope
Thirsty Bag
$9.95 · 50+ In stock
