HP Pavillion dv6000 Teardown
Teardown
Teardown
Teardowns provide a look inside a device and should not be used as disassembly instructions.
User-Contributed Guide
This guide is not managed by iFixit staff.
  • Add Note x
The motherboard died on this laptop so I thought, good enough excuse for a teardown?
Yup.
This guide should help you, regardless of whether you need to replace memory or the entire LCD.
first image
thumb image 1
thumb image 2
Add Note Edit Step 1 — HP Pavillion dv6000 Teardown  ¶
  • Remove the battery. Don’t want any charge disrupting things.
first image
thumb image 1
thumb image 2
Add Note Edit Step 2  ¶
  • Remove the 15 screws around the under body, set aside.
    • Remove the 5 screws from the battery compartment
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 3  ¶
  • Loosen the two screws from the memory shield and lift off
    • Remove the mini-pci wireless card and memory, place in an anti-static bag.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 4  ¶
  • Remove the two screws from the hard drive shield and lift off.
    • Lift out the hard drive by grasping the plastic tab and pulling gently. Place in an anti-static bag.
first image
Add Note Edit Step 5  ¶
  • Remove the one keyboard-branded screw in the memory compartment, and the one screw from the hard drive compartment.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 6  ¶
  • Use an unbent paper clip or some other stiff wire-type tool to poke in the tiny hole in the cd tray, and grasping the tray firmly, pull slowly out of the laptop.
    • Remove the 3 screws exposed by removing the drive
first image
thumb image 1
thumb image 2
Add Note Edit Step 7  ¶
  • Pop off the bezel closest to the screen, taking care not to damage the delicate ribbon cables underneath.
    • Unclip the three cables connecting the bezel to the laptop, lift away.
    • If you are struggling to get the bezel disconnected try closing the laptop and flipping it over. I did this and when I opened it again the bezel disconnected by itself.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 8  ¶
  • Lift up the back of the keyboard and slide it slowly towards the screen. Unclip the ribbon cable near the touchpad. Set the keyboard aside.
Next » « Previous
