This teardown is not a repair guide. To repair your HP Compaq 8200 Elite, use our service manual.
  1. HP Compaq 8200 Elite Teardown, Remove the cover: step 1, image 1 of 3 HP Compaq 8200 Elite Teardown, Remove the cover: step 1, image 2 of 3 HP Compaq 8200 Elite Teardown, Remove the cover: step 1, image 3 of 3
    • There are no screws to remove, simply pull the handle on the cover towards you
    • It is recommended that you do this with the PC flat on the floor
  2. HP Compaq 8200 Elite Teardown, Remove the front cover: step 2, image 1 of 3 HP Compaq 8200 Elite Teardown, Remove the front cover: step 2, image 2 of 3 HP Compaq 8200 Elite Teardown, Remove the front cover: step 2, image 3 of 3
    • There are 3 labelled tabs
    • Pull gently upward to release them
  3. HP Compaq 8200 Elite Teardown, Remove the CD-ROM: step 3, image 1 of 3 HP Compaq 8200 Elite Teardown, Remove the CD-ROM: step 3, image 2 of 3 HP Compaq 8200 Elite Teardown, Remove the CD-ROM: step 3, image 3 of 3
    • Press down on the green button
    • Pull the drive backwards until you hear a small click, then raise it out of the caddy.
  4. HP Compaq 8200 Elite Teardown, Raise the drive caddy: step 4, image 1 of 2 HP Compaq 8200 Elite Teardown, Raise the drive caddy: step 4, image 2 of 2
    • The drive caddy can be raised to allow access to the 3.5" drive bay below the CD-ROM
    • You don't have to remove the CD-ROM to do this.
    • This makes it easier to access the next 3.5" bay, too.
  5. HP Compaq 8200 Elite Teardown, Remove the 3.5" Drive: step 5, image 1 of 3 HP Compaq 8200 Elite Teardown, Remove the 3.5" Drive: step 5, image 2 of 3 HP Compaq 8200 Elite Teardown, Remove the 3.5" Drive: step 5, image 3 of 3
    • The power supply is hinged, and swings away to reveal a 3.5" bay below.
    • As with the CD-ROM, press the green button to release the drive.
    • Pull back then up to remove.
    • Depending on your configuration, there may not be a drive in this bay.
  6. HP Compaq 8200 Elite Teardown, Access the PCI-E slots: step 6, image 1 of 3 HP Compaq 8200 Elite Teardown, Access the PCI-E slots: step 6, image 2 of 3 HP Compaq 8200 Elite Teardown, Access the PCI-E slots: step 6, image 3 of 3
    • In the bottom-right corner, there is a tab
    • Lifting this up allows screw-free installation of PCI-E cards.
  7. HP Compaq 8200 Elite Teardown, Remove the fan shroud: step 7, image 1 of 3 HP Compaq 8200 Elite Teardown, Remove the fan shroud: step 7, image 2 of 3 HP Compaq 8200 Elite Teardown, Remove the fan shroud: step 7, image 3 of 3
    • Make sure to unclip the cables routed through the shroud before removing it.
    • Only a very minor amount of force is required to remove the shroud.
    • This will allow you to replace the CPU heatsink or fan.
  8. HP Compaq 8200 Elite Teardown, Points of interest: step 8, image 1 of 3 HP Compaq 8200 Elite Teardown, Points of interest: step 8, image 2 of 3 HP Compaq 8200 Elite Teardown, Points of interest: step 8, image 3 of 3
    • This workstation comes with spare Torx screws.
    • 5 Silver, 5 Black
    • Mine is missing one
    • These are also bitted for a flathead, but I had no luck actually unscrewing with one, so it's not recommended.
    • They are screwed into the chassis under the front cover
    • All screws in this device are Torx TR20. Ensure you have the correct bits before attempting board replacements
Darohan
283 Reputation
1 Guide authored
3 Comments
I want this (pcb)motherboard please show amount
Manoj subhash narwade - Reply
i accadentally blew it up
Cosmo - Reply
thanks i needed this<3
Vega Star - Reply
Past 24 Hours: 3
Past 7 Days: 32
Past 30 Days: 182
All Time: 2,532
