Garmin - Asus Nuvifone G60 Teardown
Private
Private
This guide will not appear in search results but can still be viewed by anyone!
Teardown
Teardown
Teardowns provide a look inside a device and should not be used as disassembly instructions.
User-Contributed Guide
This guide is not managed by iFixit staff.
  • Add Note x
Just a quick teardown of the Nuvifone. I apologize for the bad lighting, I don't have much to work with.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 1 — Garmin - Asus Nuvifone G60 Teardown  ¶
  • Front frame & back frame
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 2  ¶
  • Insert wisdom here.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 3  ¶
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 4  ¶
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 5  ¶
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 6  ¶
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 7  ¶
first image
thumb image 1
thumb image 2
Add Note Edit Step 8  ¶
Next » « Previous
Required Tools
T6 Torx Screwdriver
$4.95 · 50+ in stock
Flathead 3/32" or 2.5 mm Screwdriver
Recommended Tools
Home Tech Toolkit
$24.95 · 50+ in stock
Sorting Tray
$7.95 · 47 in stock
Anti-Static Wrist Strap
$7.95 · 22 in stock
Pro Tech Base Toolkit
$59.95 · 50+ in stock
Thirsty Bag
$6.95 · 50+ in stock
Popular Products
iPhone 3GS Front Panel Kit
$39.95 · 50+ in stock
Phillips #00 Screwdriver
Metal Spudger Set
$7.95 · 50+ in stock
54 Bit Driver Kit
Heat Gun
$24.95 · 13 in stock
Notes Add Note Notes are offturn on
