This teardown is not a repair guide. To repair your GEN 2 Wheelchair, use our service manual.
  1. GEN 2 Wheelchair Teardown, GEN 2 Wheelchair Teardown: step 1, image 1 of 3 GEN 2 Wheelchair Teardown, GEN 2 Wheelchair Teardown: step 1, image 2 of 3 GEN 2 Wheelchair Teardown, GEN 2 Wheelchair Teardown: step 1, image 3 of 3
    • Find a clean area to work in so every part can be accounted for.
  2. GEN 2 Wheelchair Teardown: step 2, image 1 of 3 GEN 2 Wheelchair Teardown: step 2, image 2 of 3 GEN 2 Wheelchair Teardown: step 2, image 3 of 3
    • Remove the footrest by unscrewing the lower bolt, using the 10 mm wrench.
    • Remove the upper bolt above the socket.
    • Slide out the footrest and unscrew the plate welded to the socket.
    • Slide the plate upward and off of the track to remove.
    • Untie the foot retention belt.
  3. GEN 2 Wheelchair Teardown: step 3, image 1 of 2 GEN 2 Wheelchair Teardown: step 3, image 2 of 2
    • Undo the seatbelt.
    • Remove the seat cushion by pulling it off of the velcro.
    • Remove the back padding by untieing the straps attached to the back pad.
  4. GEN 2 Wheelchair Teardown: step 4, image 1 of 1
    • Turn the wheelchair upside down and untie the plastic seat.
    • Remove the plastic seat support.
  5. GEN 2 Wheelchair Teardown: step 5, image 1 of 1
    • Locate the plastic cap on top of the caster wheels.
    • Place the 10mm wrench underneath the plastic cap and lift it up to remove.
  6. GEN 2 Wheelchair Teardown: step 6, image 1 of 2 GEN 2 Wheelchair Teardown: step 6, image 2 of 2
    • Remove the caster wheels by unscrewing the bolt under the cap with a 19 mm wrench.
    • Lift the wheelchair up to pull the caster wheels off.
    • Use caution: The metal sheath and the bearing of the caster wheel is not attached and may fall off upon removal.
  7. GEN 2 Wheelchair Teardown: step 7, image 1 of 1
    • Use a 1/2 inch socket wrench to unscrew bolts to remove the brakes.
    • Pull the brakes off.
  8. GEN 2 Wheelchair Teardown: step 8, image 1 of 2 GEN 2 Wheelchair Teardown: step 8, image 2 of 2
    • Remove the wheels by placing a 19 mm socket wrench on the inside of the wheel and unscrew the bolt.
    • Unscrew the bolt on the outside of the wheel by using a 19 mm socket wrench.
  9. GEN 2 Wheelchair Teardown: step 9, image 1 of 3 GEN 2 Wheelchair Teardown: step 9, image 2 of 3 GEN 2 Wheelchair Teardown: step 9, image 3 of 3
    • Unscrew all of the 10mm bolts on the frame using the 10 mm wrench (15 bolts total).
    • Separate the handle frame pieces from the metal side structure (2 bolts total).
    • Remove the bolts attaching the three support beams (4 bolts each, 12 bolts total).
  10. GEN 2 Wheelchair Teardown: step 10, image 1 of 1
    • Remove the bolt with the rubber cap that attaches the air pump to the center support on the bottom.
  11. GEN 2 Wheelchair Teardown: step 11, image 1 of 1
    • Congratulations! Your teardown is now complete. Make sure all of the parts are accounted for before storing or shipping.
Jennifer
32 Reputation
1 Guide authored
Cal Poly, Team 14-8, Maness Spring 2013 Member of Cal Poly, Team 14-8, Maness Spring 2013
CPSU-MANESS-S13S14G8
5 Members
7 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 17
All Time: 2,301
