This teardown is not a repair guide. To repair your Emachine C2881, use our service manual.
  1. Emachine C2881 Teardown, Emachine C2881 Teardown: step 1, image 1 of 2 Emachine C2881 Teardown, Emachine C2881 Teardown: step 1, image 2 of 2
    • Before you begin: Please unplug the unit from the wall along with any other cables and hold the power button down for 30 seconds to discharge any static energy. Also please do not work on carpet and wear a wrist strap.
    • First, loosen but do not remove the two thumb screws at the back on the left side.
  2. Emachine C2881 Teardown: step 2, image 1 of 2 Emachine C2881 Teardown: step 2, image 2 of 2
    • Next, slide the back panel towards the back of the unit.
    • Then set the panel aside.
  3. Emachine C2881 Teardown: step 3, image 1 of 3 Emachine C2881 Teardown: step 3, image 2 of 3 Emachine C2881 Teardown: step 3, image 3 of 3
    • Turn the unit on its side
    • Then remove the screw securing the hard drive bay in place.
  4. Emachine C2881 Teardown: step 4, image 1 of 3 Emachine C2881 Teardown: step 4, image 2 of 3 Emachine C2881 Teardown: step 4, image 3 of 3
    • Disconnect the hard drive power cable, and data cable.
    • And remove the hard drive bay
  5. Emachine C2881 Teardown: step 5, image 1 of 3 Emachine C2881 Teardown: step 5, image 2 of 3 Emachine C2881 Teardown: step 5, image 3 of 3
    • Remove the 2 phillips head screws on the hard drive bay.
    • Then push the hard drive up and then pull it out
  6. Emachine C2881 Teardown: step 6, image 1 of 3 Emachine C2881 Teardown: step 6, image 2 of 3 Emachine C2881 Teardown: step 6, image 3 of 3
    • To remove the front panel, Grasp the top, and pull it outward and upward.
    • Don't pull it out too hard, as there are three cables still connected to the panel.
  7. Emachine C2881 Teardown: step 7, image 1 of 3 Emachine C2881 Teardown: step 7, image 2 of 3 Emachine C2881 Teardown: step 7, image 3 of 3
    • Push the clips back on the 2 LED´S and the power switch to remove each.
    • And then remove the front panel.
  8. Emachine C2881 Teardown: step 8, image 1 of 3 Emachine C2881 Teardown: step 8, image 2 of 3 Emachine C2881 Teardown: step 8, image 3 of 3
    • Remove the single screw securing the audio box.
    • Then rotate it 90 degrees down and pull it forward
  9. Emachine C2881 Teardown: step 9, image 1 of 3 Emachine C2881 Teardown: step 9, image 2 of 3 Emachine C2881 Teardown: step 9, image 3 of 3
    • Remove the two screws on the audio box. Then pull it out and set the case aside.
  10. Emachine C2881 Teardown: step 10, image 1 of 3 Emachine C2881 Teardown: step 10, image 2 of 3 Emachine C2881 Teardown: step 10, image 3 of 3
    • Remove the single screw from the SD card reader.
    • Then remove it
  11. Emachine C2881 Teardown: step 11, image 1 of 3 Emachine C2881 Teardown: step 11, image 2 of 3 Emachine C2881 Teardown: step 11, image 3 of 3
    • Now remove the 2 screws from the DVD player. Disconnect the cables and remove it.
  12. Emachine C2881 Teardown: step 12, image 1 of 3 Emachine C2881 Teardown: step 12, image 2 of 3 Emachine C2881 Teardown: step 12, image 3 of 3
    • Turn the computer back on its side
    • Remove the cables for the card reader, and the audio box and remove all of the above.
  13. Emachine C2881 Teardown: step 13, image 1 of 3 Emachine C2881 Teardown: step 13, image 2 of 3 Emachine C2881 Teardown: step 13, image 3 of 3
    • Disconnect the DVD drive cables, and the hard drive cables and set them aside.
  14. Emachine C2881 Teardown: step 14, image 1 of 3 Emachine C2881 Teardown: step 14, image 2 of 3 Emachine C2881 Teardown: step 14, image 3 of 3
    • Remove the RAM by pushing down on the two tabs. Then pull up on the RAM
  15. Emachine C2881 Teardown: step 15, image 1 of 3 Emachine C2881 Teardown: step 15, image 2 of 3 Emachine C2881 Teardown: step 15, image 3 of 3
    • Remove the single screw securing the phone card. Then pull it up and out.
  16. Emachine C2881 Teardown: step 16, image 1 of 3 Emachine C2881 Teardown: step 16, image 2 of 3 Emachine C2881 Teardown: step 16, image 3 of 3
    • Remove the four screws securing the back fan. Disconnect the cable
    • Pull the fan out of the inside of the case
  17. Emachine C2881 Teardown: step 17, image 1 of 3 Emachine C2881 Teardown: step 17, image 2 of 3 Emachine C2881 Teardown: step 17, image 3 of 3
    • Disconnect the 20 Pin motherboard cable and the four pin cable.
  18. Emachine C2881 Teardown: step 18, image 1 of 3 Emachine C2881 Teardown: step 18, image 2 of 3 Emachine C2881 Teardown: step 18, image 3 of 3
    • Remove the six screws from the motherboard, one in each corner and two in the middle in between these
  19. Emachine C2881 Teardown: step 19, image 1 of 3 Emachine C2881 Teardown: step 19, image 2 of 3 Emachine C2881 Teardown: step 19, image 3 of 3
    • Grasp the motherboard by the side that would face the front of the computer, and pull it towards the front, and then up.
  20. Emachine C2881 Teardown: step 20, image 1 of 3 Emachine C2881 Teardown: step 20, image 2 of 3 Emachine C2881 Teardown: step 20, image 3 of 3
    • Remove the Heatsink clips by pushing down and out on the clips.
  21. Emachine C2881 Teardown: step 21, image 1 of 2 Emachine C2881 Teardown: step 21, image 2 of 2
    • Disconnect the fan cable and lift the heat sink up
  22. Emachine C2881 Teardown: step 22, image 1 of 2 Emachine C2881 Teardown: step 22, image 2 of 2
    • Remove the four screws from the heatsink fan and remove the fan.
  23. Emachine C2881 Teardown: step 23, image 1 of 3 Emachine C2881 Teardown: step 23, image 2 of 3 Emachine C2881 Teardown: step 23, image 3 of 3
    • Remove the four screws from the power supply and then pull it back and out
  24. Emachine C2881 Teardown: step 24, image 1 of 1
    • Congradulations you have successfully torn down your emachine model C2881
Duncan Rutherford
278 Reputation
2 Guides authored
2 Comments
This workaround is not ESD conform.
You have a high risk of damaging the electronic components.
For more Information see here:
for german: https://de.wikipedia.org/wiki/Elektrosta...
for english: https://en.wikipedia.org/wiki/Electrosta...
42 - Reply
Before Attempting to Do this Please get a ESD are antistatic mat to work on, if not then you will damage components in the system, when in doubt ask someone in the profession the right way of going about it.
Donald Tidwell - Reply
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 30
All Time: 2,330
