Elster REX2 Smart Meter Teardown
Teardown
Teardown
Teardowns provide a look inside a device and should not be used as disassembly instructions.
The electricity meter is one device that no household connected to the grid can escape, and the technology utilized by analog meters (the most common type) dates to the late 19th century. However, engineers have recently developed a solid state electronic meter that sends electricity consumption readings wirelessly. This new meter eliminates human error and allows utility companies to monitor their systems more accurately.
We were always interested in these meters, but had trouble acquiring one for a teardown -- it's not like you can just walk into a Best Buy and pick one off the shelf. Thankfully, the generous folks over at Elster were kind enough to send us one of their REX2 meters for thorough dissection!
The controversy surrounding the implementation of smart meters prompted us to take a close look at their hardware to see what exactly makes these devices tick.
Image #1
Add Note Edit Step 1 — Elster REX2 Smart Meter Teardown  ¶
  • While utility companies prepare to deploy smart meters to everyone, we -- being the resourceful people that we are -- acquired one for all our fans.
  • Introducing the energy meter of the future: the Elster REX2 Watthour meter.
  • The REX2 meter provides several enhancements over non-programmable meters:
    • Nonvolatile memory rated for 1,000,000 write cycles
    • Advanced security with full 128-bit AES encryption
    • Remote upgradeability
    • Support for 900 MHz and 2.4 GHz ZigBee communication
    • Optional: flux capacitor add-on???
Image #1 Image #2
Add Note Edit Step 2  ¶
  • The following teardown features dissection performed either by professionals or people who consider themselves to be professionals. Please do not attempt to recreate or re-enact this teardown unless you're fond of getting into trouble with your power company.
  • Before gaining access to the interior of the meter, you must first break a security seal.
    • Apparently, electric companies don't want you tampering with their meters. Go figure!
  • After removing the security seal, the clear plastic cover lifts off easily with a twist of the wrist.
Image #1 Image #2
Add Note Edit Step 3  ¶
  • Our Elster REX2 smart meter is labeled as Type R2S. The 2S model has an operating voltage rating of 240 V ranging from 192 V to 288 V at a nominal frequency of 60 Hz.
  • Who would've thunk that your watthour meter would have a LAN ID? A LAN ID is required to connect to the IP-based EnergyAxis Smart Grid network.
  • Elster's meters operate on 25 channels across the 902-928 MHz ISM band using a controlled path mesh.
    • A "controlled mesh" network is created when the thousands of smart meters in a city communicate with each other to relay power readings to a gateway device that indirectly channels the readings to a utility company. Elster's meters find the best path between themselves and other meters on the grid so that noise and duplication from repetitive signals is at a minimum. This works so well that only one in ten smart meters is used as a repeater to relay signals from other meters.
  • If a specific household has concerns about their meter being used as a repeater, they can contact their utility company to request that their Elster meter transmits power readings just once a day.
Image #1 Image #2
Add Note Edit Step 4  ¶
  • The two halves of the case are held together with four plastic clips.
  • Once all the clips are depressed, the two halves "pop" apart making access to the internals easier.
  • Separating the two halves provides the first glimpse of the meter's surprising deficiency of internal components.
Image #1 Image #2 Image #3
Add Note Edit Step 5  ¶
  • After disconnecting a single cable, we get a good look at the smart meter's power connections.
  • The retaining clips holding the power connections to the back of the rear case are easily removed using our large needle-nose pliers.
  • After a bit of wiggling, the power connections come out with little resistance.
Add Note Edit Step 6  ¶
  • Extremely thick copper wires allow the meter to be wired in series with a household's main power supply. They're capable of handling 200 Amps!
  • Interestingly, the meter relies on a black ring-shaped current transformer installed around the copper wires to send power consumption signals to the main board.
    • Current transformers indirectly measure the current flowing through the thick copper conductors and provide an output that can be read by the electronics on the board.
  • Long metal pressure contacts along the inside case of the meter conduct 240V AC electricity to pads that provide power to the main board.
Image #1 Image #2
Add Note Edit Step 7  ¶
  • Well what have we here? Can this be true? In the whole device there is only one screw, a surprisingly difficult to find Phillips #1.
  • After pushing a few clips aside, the motherboard is easily removed from the front case.
Image #1
Add Note Edit Step 8  ¶
  • Main IC's located on the front side of the motherboard include:
  • Two pads near the top of the board channel 240V AC electricity from the large copper wires onto the board and into the adjacent blue transformer box that steps it down to about 10V AC. From there, the AC voltage is rectified and conditioned to power the DC components on the board.
Next » « Previous
Required Tools
Phillips #1 Screwdriver
$4.95 · 5 In stock
Large Needle Nose Pliers
$4.95 · 5 In stock
Recommended Tools
Universal Drive Adapter
$29.95 · 50+ In stock
Inspection Scope
$39.95 · 17 In stock
Portable Anti-Static Mat
$24.95 · 11 In stock
Popular Products
Unibody Laptop Dual Drive
$39.95 · 3 In stock
iPad 2 Bluetooth/Wi-Fi Antenna
$24.95 · 1 In stock
Plastic Opening Tools
$2.95 · 50+ In stock
Heavy-duty Spudger
$4.95 · 49 In stock
