This teardown is not a repair guide. To repair your Dualshock 2, use our service manual.
  1. Dualshock 2 Teardown, Removing the Screws: step 1, image 1 of 1
    • On the back of the controller there is screw holes
    • Using a Philip Screw driver remove the screws
  2. Dualshock 2 Teardown, Separating the controller pieces: step 2, image 1 of 3 Dualshock 2 Teardown, Separating the controller pieces: step 2, image 2 of 3 Dualshock 2 Teardown, Separating the controller pieces: step 2, image 3 of 3
    • Using a pry tool separate the two controller pieces
  3. Dualshock 2 Teardown, All the buttons: step 3, image 1 of 3 Dualshock 2 Teardown, All the buttons: step 3, image 2 of 3 Dualshock 2 Teardown, All the buttons: step 3, image 3 of 3
    • First remove the buttons
    • Most of my buttons fell off. Then left up on the sensor and set it aside.
  4. Dualshock 2 Teardown, DualShock support: step 4, image 1 of 2 Dualshock 2 Teardown, DualShock support: step 4, image 2 of 2
    • When I lifted the controller out of the chassis one of the dual shock motors fell off it soldering. I removed the other one.
  5. Dualshock 2 Teardown: step 5, image 1 of 1
    • What you are left with
zachary
792 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 11
Past 30 Days: 62
All Time: 9,843
